more xantia suspension!
alab
The rear suspension on my bosses L reg Xantia TD has suddenly decided not to rise at all in normal use. The front behaves fine, but the only way to get the back up is to move the lever up, then the rear goes up to max height, but stays there. It will go right down if you move the lever to min, but it is full height or nothing! As the car is not mine, I am not sure about the history, but as far as I know everything else is ok. If anyone can help, I would be very grateful! (so would my boss!) Alastair (87 BX19RD, 90 XM2.0Sei, 71 Morris Minor Pick Up!)
Dave Burns
