citroenxm wrote:You didnt need my hdi belt change guide then jim?
I looked at it Paul, to brief myself on the job and then basically followed how I'd do an XU belt and delighted myself in generally finding the job more straightforward
So your giode was invaluable...
The HDi is clearly a close evolution of the XUD but it's good to see PSA have improved things along the way - better cam cover design, although they still have some fiddly bolts
and a much better auxiliary belt tensioning arrangement are just two that come to mind and to me, access seems better. Small improvements that make a big difference...
If you see an HDi as an XUD with a different head then you aren't really far wrong... Buy yes, I agree - once the delights of an HDi have been sampled it has to be said it is a massive improvement on the XUD9 although not so noticeably different from an XUD11 except it's revvier. I stand by my view that the HDi encompasses the best of both the XUD9 and XUD11 in one engine.
One thing you can't escape from is that if the HDi conks out then you're stranded. The XUD9 on the other hand being mostly mechanical and simple, can be rigged in all sorts of ways to get you home; as Xac can attest. This will always be the strong point of the XUD9 and you can't argue against that in any way.
We did the cambelt and water pump on Chris570's HDi today so that's two HDi cambelts in as many weekends... The only main difference from mine was the use of a SEEM gauge on Chris's to set the tension. That's a jolly critical and sensitive adjustment!
I gave Rattiva a good run along the fast roads to and from Chris's and was pleased to note rather more cabin heat was available when driven in a more spirited manner
