C5 2.2HDi ESPR & Anti-Pollution Faults
cachaciero
My Cars:
x 9
Re: C5 2.2HDi ESPR & Anti-Pollution Faults
Post by cachaciero »
sirlynedoch wrote:No it will not rev past 4000 in neutral or any other gear.
Have you checked that you are getting maximum out of the throttle sensor.
On my 2.2 when I first had it the cable had stretched so much that even with the pedal to the floor the throttle sensor (pot) still had a way to go, was much better after adjustment :-)
Unfortunately it's not so easy to get at and means taking the injector ECU out to get at it.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
sirlynedoch
My Cars:
Post by sirlynedoch »
Thanks very much to David H for the Lexia Diagnostic. Excellent piece of equipment. Came up with -
Here's the faults and the tests that we've carried out tonight:
permanent fault - fuel filler cap sensor signal
permanent fault - inlet air temperature signal. CAN value not possible.
permanent fault - flowmeter signal. Short circuit to earth or open circuit flow too low
exhaust gas recycling valve electrovalve - OK
exhaust gas recycling throttle valve - OK
swirl throttle electrovalve - OK
turbo charger pressure solenoid valve - OK
additive pump working OK
additive injector working OK
eolys fluid counter reset
measured air flow @ 4000rpm was 500mg/cp
measured air flow @ 2500rpm was 595mg/cp
Car still running underpowered and will not rev past 4000rpm.
Any ideas anyone?
DickieG
Monaco's youngest playboy
My Cars:
x 38
Post by DickieG »
Have you tried a new MAF sensor? I believe the inlet temperature sensor and flowmeter signal faults are related to a duff MAF sensor, from memory on this forum use a genuine item as I believe spurious ones are unreliable.
With the Eolys fluid counter reset you mention, was it reset and if so to what?
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX
x 4888
Post by myglaren »
DickieG wrote:Have you tried a new MAF sensor? I believe the inlet temperature sensor and flowmeter signal faults are related to a duff MAF sensor, from memory on this forum use a genuine item as I believe spurious ones are unreliable.
Agreed - those results do indicate a MAF fault.
I had similar symptoms a while back and replacing the MAF made a very impressive difference.
cachaciero
My Cars:
x 9
Not relevant to your current fault but note also the filler cap sensor, lack of this means that the Eolys will not get injected into the fuel, which means sooner rather than later the FAP will choke up with unburnt carbon.
Note do not assume that because it says that the electro valves are working that the bits that are attached e.g swirl valves are working properly, e.g you could have a total lack of vacuum it will still report that all the EV's are o.k but swirl valves, egr, turbo etc will not be working. Though with total vacuum loss you would have no brakes and turbo overboost.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
sirlynedoch
My Cars:
Ok guys,
Have just tried a new MAF and the car is still underpowered and lumpy , will not rev past 3500 revs.
Comes up with anti-pollution fault and espr not working.
Any more ideas?
Post Reply
