as i said earlier now you feel you have removed enough citro blood, pull the two wires from the bottom of the float then turn/rotate the bsase about 1/4 of a turn, then lift it out to see if there is anything appart from citro blodd stopping the float from dropping,
the float and the spindle the disc's attatch to are moulded from one piece of plastic,
regards malcolm
lhm tank level indicator
