Agreed - my local dealer has it listed as a boost pressure sensor.torq wrote:Paul-R wrote:MAPs are for petrol not diesel so nothing applies I'm afraid.
Acording to the Citroën parts catalogue, the dw10ated engine has a MAP sensor. It's hosed to the top of the intercooler, part no 1920gh.
38mpg at 70mph. 2004 C5 estate 110bhp
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4922
Re: 38mpg at 70mph. 2004 C5 estate 110bhp
Why not try some Wynns EGR3 spray. This can clean all the crud out of the inside of your inlet manifold and off your inlet valves.
I tried it and it made quite a difference.
Cheers, Kev
- x 9
Quite correct, on a turbo equipped engine a diesel injection system needs to know the inlet pressure as much as a petrol injection system does.torq wrote:Paul-R wrote:MAPs are for petrol not diesel so nothing applies I'm afraid.
In the case of a diesel the pressures it will measure are all positive and are effectively a measure of the turbo pressure. If this sensor was defective in the sense that it indicated a higher pressure than actually existed the injection system would tend to overfuel the engine. However I would expect there to be a monitor loop within the logic that would check the sensor output against engine revs and maybe throttle position this loop would have a map of expected manifold pressure for these values, if the sensor was outside this map it would post an error. Well that's how I would write the software anyway
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1380
Mmmm, well I suppose you could say that if we're talking about absolute pressure then that can be either positive or negative relative to normal atmospheric pressure. However, the MAP in the link is for vacuum measurement which is then used to provide data for the petrol injection. The pressure sensor in the DW10ATED engine measures the pressure of the Turbo above atmospheric norm.
- x 9
Oh! so a turbo charged petrol engine doesn't have positive pressure in the manifold then ? I believe that your first sentence was the correct one, it measures absolute pressure that way it takes into account altitude as well.Paul-R wrote:Mmmm, well I suppose you could say that if we're talking about absolute pressure then that can be either positive or negative relative to normal atmospheric pressure. However, the MAP in the link is for vacuum measurement which is then used to provide data for the petrol injection. The pressure sensor in the DW10ATED engine measures the pressure of the Turbo above atmospheric norm.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
- Paul-R
- Donor 2023
There aren't that many turbocharged petrol engines around and I wonder whether they have two pressure sensors, one for positive pressure and one for vacuum. It would probably be easier than engineering a sensor that could cope with both positive and negative pressure.
Coming back to PSA I believe that altitude in the HDi is measured by a sensor in the ECU.
This evening I
Unplugged the MAP and MAF while the engine was running. The idle went rough when the MAF was unplugged. Plugged back in and ignored the EML, I'll Lexia it at the weekend. Drove home at an average of 67mph for 17miles and got a reported 47.1mpg from the OBC, my best to date!
The bosch book gives the following sensors and set point generators
Road speed sensor
Crankshaft speed sensor
Camshaft sensor
Engine temperature sensor
Intake air sensor
Boost pressure sensor(MAP)
Hot film air-mass meter (MAF)
Road speed sensor
Camshaft sensor
Intake air sensor
- x 9
At the end of the day a pressure sensor is a pressure sensor it's how you calibrate it that counts.Paul-R wrote:There aren't that many turbocharged petrol engines around and I wonder whether they have two pressure sensors, one for positive pressure and one for vacuum. It would probably be easier than engineering a sensor that could cope with both positive and negative pressure.
If the sensor has a voltage output you can arrange for it to have an output of say 0Volts at 1013mb and say 12V @ 3000mb such a calibration would only give you an output for pressure above 1013mb. On the other hand you could calibrate the same sensor to give you an output voltage of say 3Volts @1013mb such an arrangement would give you a meaningful output for pressures positive and negative about normal atmospheric.
Not aware of a separate sensor in the ECU, which doesn't mean there isn't one but I can't see why one would be needed, the engine is only interested in the absolute amount and pressure of air going into the engine which the ECU can calculate from Mass Flow (MAF) and manifold Pressure (MAP) altitude per se is irrelevant, the effects are already taken into account.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
The atmospheric pressure sensor is part of the ECU in both the SID and EDC controlled HDIs.
- x 9
So it is. You made me go away and do some more studying Still can't work out why they would need it though.BX wrote:The atmospheric pressure sensor is part of the ECU in both the SID and EDC controlled HDIs.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
We don't really have this in the UK so it may not be immediately obvious but some countries - America is the one that springs to mind first, there are many regions that are significantly above sea level* and the normal barometric pressure consequently lower which has a huge impact on performance.
Perhaps the sensor in the ECU detects the ruling barometric pressure and compensates for the deviation from standard sea level pressure of 14.696 psi.
*I may be wrong here but I have the feeling that some regions in Utah are below sea level.
- x 9
You are correct even in Europe we have high mountain ranges e.g. the Alps which can make a big difference to engine performance.myglaren wrote:We don't really have this in the UK so it may not be immediately obvious but some countries - America is the one that springs to mind first, there are many regions that are significantly above sea level* and the normal barometric pressure consequently lower which has a huge impact on performance.
I was writing an explanation on how altitude was irrelevant as things such a MAP and MAP would automatically take care of it which they do as far as fueling is concerned but it suddenly occurred to me that as the inlet pressure falls what you really want is for the turbo to compensate for this auto magically, with a separate barometric sensor this becomes possible at least with a variable geometry turbo, not sure how this could be achieved using a non variable geometry turbo. Another very useful feature of a separate barometric sensor is that it enables a calibration check of the Manifold Pressure sensor, with engine stopped i.e at switch on the output of both sensors should indicate the same pressure.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
Today I bypassed the MAP. Drove 20miles at 70mph and 2.3k rpm with no effect. Temp stayed the same as did performance and I got 41.5mpg. Will try another 40miles tomorrow to see but it appears the MAP has no input at steady engine speeds.
T
T
- My Cars: 07 Citroen C6 V6 HDi Exclusive - Red
07 Citroen C5 HDi VTR - Red
09 Citroen C3 1.4i VTR - Silver
01 Citroen Saxo 1.1i Forte - Mango Orange
93 Ford Mondeo 2.0i GLX
19 Hyundai i10 - x 110
So is it even working?torq wrote:Today I bypassed the MAP. Drove 20miles at 70mph and 2.3k rpm with no effect. Temp stayed the same as did performance and I got 41.5mpg. Will try another 40miles tomorrow to see but it appears the MAP has no input at steady engine speeds.
T
Ive replaced a few on 2.0HDi 110 C5s, often they don't store a fault code but fitting a new MAF sensor restored performance and economy. On one occasion it did store a fault code.
Cheap MAF sensors are not worth anything in my opinion, you might as well stick with an old and broken one. I had to replace a cheapy with a genuine one as it just wasn't working correctly.
19 Hyundai i10
19 Hyundai i10
- x 9
How did you bypass the MAF? mechanically or electrically? I found on my 2.2 that bypassing the MAF (air bleed downstream of MAF) made quite a substantial difference much more than I was expecting, acceleration was much poorer and power seemed to be down over much of the low / mid rev range.torq wrote:Today I bypassed the MAP. Drove 20miles at 70mph and 2.3k rpm with no effect. Temp stayed the same as did performance and I got 41.5mpg. Will try another 40miles tomorrow to see but it appears the MAP has no input at steady engine speeds.
T
Edit
Edited to reflect what I was thinking, which actually had little to do with the post I was responding to.........
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
