An update regarding the problem with the ABS, Lexia showed permanent fault with the pump, checked all over inc the connectors. Looked like it was going to be a new pump. The brake fluid looked a little on the dark side, flushed out the fluid and the ABS fault solved.
Thank you to all for your help.
Atma
Lexia help in Hampshire
Re: Lexia help in Hampshire
The most effective way by far to help the environment is to stop eating animals......
