xantia droning from rear wheels?.
jimmydod
My Cars:
Xantia droning from rear wheels?.
Post by jimmydod »
Thank you all,
I must add I was not driving when I had my head in the boot; such contortions are past for an oldster like me. Will hopefully do other hub and look for any wear in sub frame bushes suspension arm bearings over this coming week end. As regards brake backplate noted top mounting bolt on r/h side has been sheared will also anchor this by drilling a 6mm+ hole and fit a new bolt and nylocnut above were the sheared one is. Do not have any untoward bangs knocks etc when going over speed bumps. Will keep you informed as to how I go on.
kind Regards to all
jim the geriatric
My Cars: Bluebell the AX, Polly the C3 Picasso, Pix the Nissan Pixo, Propel the duathlon bike, TCR Pro the road bike and Fuji the TT bike...
x 6174
Contact:
Post by CitroJim »
I wonder if the missing backplate bolt was causing the plate to oscillate and thus set up the droning?
Quite possible...
wotwot
(Donor 2021)
My Cars: 1982 GSA 1299
1984 bx 1600
zx 5 door x 2
xantia estate
dispatch
xara picasso
806
807 SE
x 4
Post by wotwot »
I've just been out in my xantia and my suspect drive shaft drone "sounds" like its coming from the rear like yours damn. So in respect of broken back plates or bolts I have neither of these.
Will be getting the wheels off the ground to check out bushes and bearings, and will get back to you all.
Mine noice becomes more pronounced "not noisier" when braking from speed clutch depressed or not ?.
My Cars: 2006 C5 2.0 Litre HDI VTR Automatic Estate.(now sold on)
Currently Renault Zoe 2014 ZE
x 2507
Post by Gibbo2286 »
Have you tried changing the wheels round, some poor quality tyre treads can be noisy?
Also directional tyres fitted wrongly can do the same.
My Cars: MK2 '17 C4GP 1.6 BlueHDi 120
'13 3008 1.6 HDi GripControl
x 994
Post by RichardW »
If you fitted a new hub then it won't be that - I'm very surprised you got it off withouth pulling the bearing in half though :? So, it's the car fooling you - it's either the other rear one of one of the fronts. You should be able to feel / hear some roughness in the suspect bearing with it jacked up. Whilst normal wisdom says that wheel bearings go quiet when unloaded (ie a RH bearing goes quiet on a RH bend) - I had one go in my first Xantia, and that went quiet when loaded up. But that's Citroen for you :lol: Duff ones in the Picasso were just noisy all the time!
wotwot
(Donor 2021)
1984 bx 1600
zx 5 door x 2
xantia estate
dispatch
xara picasso
806
807 SE
x 4
Post by wotwot »
Thats it another sensor.
A sensor to tell you the bearings are worn out,we dont have enough sensors to go wrong on our cars.
So i'm just applying for the patent as i type.I will make a fortune at £55 per sensor x4 per car i'm rich,and everyone will have to get there lexia upgraded for the new sensor fault code.
8-)
addo
Sara Watson's Stalker
Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
My Cars: Peugeot 605
Citroën Berlingo
Alfa 147
x 93
Post by addo »
I'll order a set, then refuse to pay.
wotwot
(Donor 2021)
1984 bx 1600
zx 5 door x 2
xantia estate
dispatch
xara picasso
806
807 SE
x 4
Post by wotwot »
But i'll be so rich with the mugs that do pay I'll be able to send the boys round.
They will convince you that swimming with the fishies is not the best option.
Xaccers
My Cars:
x 184
Post by Xaccers »
So, how best to fully diagnose it? Jump in the boot and get someone to drive me at 50-60mph while I listen for the noise?
There's been a pulsing vibration for a couple of months too.
DIY sphere tool
DickieG
Monaco's youngest playboy
My Cars:
x 38
Post by DickieG »
Xac wrote:There's been a pulsing vibration for a couple of months too.
That sounds like an out of shape tyre, lift the wheel off the ground and spin it.
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
addo
Citroën Berlingo
Alfa 147
x 93
Post by addo »
No, it's disco music through a subwoofer. :P
When you've got a few bits marginally out of whack (say, driveshaft, wheel, tyre on different sides) they seem able to drift in and out of mutual phasing - probably due to different rates of rotation. Hence a pulsation can occur.
jimmydod
My Cars:
rear wheels droning?
Post by jimmydod »
Xantidote wrote:Having replaced the nearside rear hub, and proved that wasn't the problem, you could try refitting the original hub to the offside and see if the noise disappears. Assumes you didn't damage the original when taking it off, and that you haven't already thrown it away!
Did as you suggested also reanchored brake back plate. Cleand and repacked bearings with grease fitted to r/h side and lo and behold runs smooth as can be. Amazing was totally convinced noise was from l/h side just shows how sound can confuse us many thanks to all contributors for your helpful suggestions.
Kind Regards to all
jim the geriatric
Xantidote
My Cars:
x 5
Post by Xantidote »
Well, that's good news Jim.
I guess we all have trouble at times, tracing noises to their real source.
At least you no longer have to drive with your head stuck in the boot :lol:
Martin
1995 Xantia TDLX (deceased :( )
Post Reply
