Sl4yer wrote:Forgot to mention that the engine seems to be detuned from that in a standard C4 (199 torques instead of 236). Don't know if that is to protect the clutch, or to help the CO2 figures / economy. There is quite an increase in acceleration at 3000rpm though, so quite possibly the latter.
Cheers James.
Using a highly techinical algorythm , based on sticking a pin in most modern cars Tech Specs ....
There appears to be a Correlation twixt Power / Economy / Engine failure ? possibly always was .
e.g if 110 Ponies / enough torques are sufficient for my needs , and it can be achieved by an older Tech HDI 2.0 8v engine , as repeatedly advised on this Forum .
Why would I want to go the H.D.I 16v 1.6 motor route , with all it's other associated gubbins ? apart from modernity and a few more m.p.g ?
By it's very nature , surely extracting the same power from less cubes has to place the engine under more stress , and any subsequent repair bill will almost certainly wipe out at a stroke the supposed economy advantage .
Apologies for repeating the same sort of Q. in different posts , and I realise it will come down to sink or swim .
Or ? am I too dyed in the wool to accept change , and the fact that modern engines are a quantum leap in Errrrr what exactly
I recall a U.S Saturn -Astronaut being asked
Q. what do you think about when the lauch sequence begins ?
A. I think about being sat on a skyscraper made from over 4 million seperate components - each of which produced by the lowest bidder ....
No substitute fer Cubes ? or simply pot - luck ?
Factor in the LUST Equation , the DS, C6 , G.Pic looks gorgeous ( personal opinion) all of the above becomes meaningless , then , when it spits it's dummy - you may console yourself that
" It ain't my fault " + " the book / magazine / road test said they are O.k "
both uttered in a kneeling - whispered penetant chant in the split second before the Missus Scutches yer bonce with the rolling pin
