Save an alternator? It's fine, problem was + cables high ohm
- Xaccers
- x 184
citronut wrote:or you could fabricate a citro blood deflecter from an ice cream tube, to place between the alt and H/P pump, mind you eat the ice cream first, and it has to be a decent cornish variaty ,
also if your clever you could make it so it not only protects the altanator, but collects the citro blood and returns it to the tank
regards malcolm
Or to prevent contamination, feed it into the fuel tank
Except my hydraulic pump doesn't leak anymore.
Nope, none at all, the alternator is fine, it was the end of some of the positive feed cables in the battery clamp that were covered in verdi gris causing high resistance.wheeler wrote:Just another thought aswell, is there any chance the belt could be slipping slightly under load due to the LHM contamination ??
DIY sphere tool
DIY sphere tool
