Definitely something not right there Peter, HDi's produce more torgue at lower rev's than a 2.1, think of the money you could save if the engine is breathing correctly Joking aside it might be worth giving the cat a sensible knock prior to the Italian tune up to dislodge some of the built up soot. Citroen did produce a service bulletin on this very matter of the cat being blocked with soot.Peter.N. wrote:That uses fuel I have actually given the 406 a short blast at full throttle and it did eject a bit of soot so that maybe the problem, I will try it again when I can afford it
The 406 will pull away well at tickover but if you drop to about 1200 rpm when driving its gutless whereas the XM will pull quite well from that speed.
2.1 XM - V - 110hp 406
- DickieG
- Monaco's youngest playboy
- x 38
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
RUBBISH Peter, In the Old XUD yes a hard plod resulting in black cloud of smoke, but in these HDi I simply CANNOT get a cloud of smoke from the exhaust (Once the exhaust soot has cleared)
I only get a grey Haze.. remember these HDi's use minimal amounts even at high revs.. No wasted fuel resulting in black clouds!
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
'13 3008 1.6 HDi GripControl - x 1003
My HDi 110 pulls much better at low revs since I changed the cambelt - no idea why, the timing appeared spot on before and after, but it used to judder if you asked anything of it below 1250, but now it's fine . 50 mph = 1750 rpm in top in a Xantia HDi 110 (or any speed you like in mine, as the speedo reads 50 most of the time anyway )
