Exhaust Back Box and Anti-lock brakes - really?
Xaccers
My Cars:
x 184
Post by Xaccers »
TE is the full turbo 1.9TD 90HP
Being a diesel you don't need a cat, and being a 95' I doubt you'll have one but that doesn't mean a catted pipe hasn't been erroniously fitted in the past 15 years.
Best thing to do would be get the car on high, lie down beside it and take a look underneath.
I would expect a single length of pipe from the engine to the back box.
The CAT version should be the same length too.
Here for £50
http://www.onlineautomotive.co.uk/Produ ... yID=114090
You'll need a new clamp.
They also show the 90HDi uses the same back box
DIY sphere tool
HDI
My Cars:
x 7
Post by HDI »
Looks like the one I have may well fit then ! I'll get the part number on Monday and post it here. It's a pattern part but not Bosal, I think it's Euroflow or something like that.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
mongoose100
My Cars:
Post by mongoose100 »
Just had a look under mine, 93 NO ABS and 94 WITH ABS.
Both exhaust systems look identical to me, cant see ABS wires coming anywhere near the exhaust!!!
Hope that helps
Regan.
2001 Citroën C5 V6
1994 Citroën Xantia 1.9TD
handyman
My Cars:
Post by handyman »
Hi Regan, think you will find there is a difference in bore sizes between the two systems or the couplings are reversed to stop numpties fitting the wrong box.
Apparently, you are supposed to wrap the ABS cables around the exhaust pipe to increase its capacitance! :twisted: :twisted: :twisted:
If HDi posts up the part number, it should be possible to cross-refernce it ont'Net.
H
addo
Sara Watson's Stalker
Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
My Cars: Peugeot 605
Citroën Berlingo
Alfa 147
x 93
Post by addo »
I thought maybe the non-ABS cars had an exhaust brake like artics?
mongoose100
My Cars:
addo wrote:I thought maybe the non-ABS cars had an exhaust brake like artics?
Nope, they have thrust reversers, usually engaged as the spoilers are extended
Regan.
2001 Citroën C5 V6
My Cars: 2006 C5 2.0 Litre HDI VTR Automatic Estate.(now sold on)
Currently Renault Zoe 2014 ZE
x 2507
Post by Gibbo2286 »
The abs no abs difference may have come up at the exhaust firm by mis-reading the Citroen parts list, the list tends to separate these things and will say for example:
"TURBO DIESEL XUD11BTE AND EEC 19-5 DEPOLL (ENGINE) UNTIL RPO No. 07237 and with ABS"
or
"TURBO DIESEL XUD11BTE AND EEC 19-5 DEPOLL (ENGINE) UNTIL RPO No. 07237 and without ABS"
when referring to something that has nothing to do with the part you're looking for but has something else in that section that abs or no abs does make a difference..
Penguin
My Cars:
Post by Penguin »
Fantastic, thanks chaps. Amazing amount of help although there seems a discrepancy over the CAT, Handyman says yes, Xac says no. As soon as I can force my disease ridden body out of bed (bloody summer colds- I mean, Man Flu') I will crawl underneath and take a look.
Thanks for the offer HDi, let me know what you find out. If I can save a few quid, great! Every little helps. Hmm, maybe that should be a tag line for a shop or something :wink:
Edit: Just been outside and checked underneath. Either I don't have a CAT fitted or its really compact and fits inside the diameter of a normal piece of pipe as it's straight through from front to back.
95 Xantia 1.9td SX
Xaccers
My Cars:
x 184
Post by Xaccers »
Penguin wrote:Fantastic, thanks chaps. Amazing amount of help although there seems a discrepancy over the CAT, Handyman says yes, Xac says no. As soon as I can force my disease ridden body out of bed (bloody summer colds- I mean, Man Flu') I will crawl underneath and take a look.
Man flu is serious!
http://www.manflu.info/
DIY sphere tool
Penguin
My Cars:
Post by Penguin »
Thanks Xac, I shall forward the link to my wife. Just confirms what I've always thought to be true!
95 Xantia 1.9td SX
handyman
My Cars:
Post by handyman »
Penguin, the cat/no cat debate has absolutely no bearing on the rear box as the supercession part number now covers all particular diesel models.
If HD1 comes up with a part number, it should do the job.
H
HDI
My Cars:
x 7
Post by HDI »
Will do tomorrow, it's over at my mums garage.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
MikeT
My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon
x 231
Post by MikeT »
There's a used one going cheap in Wareham, Dorset.
Ebay item number 220815292470
Penguin
My Cars:
Post by Penguin »
Thanks for the info Mike, but it will cost a (not so) small fortune to collect. I'll see what HDI comes up with first.
95 Xantia 1.9td SX
HDI
My Cars:
x 7
Post by HDI »
It's a Euroflow part, EXCN6010. Have been on their website but the catalogue cannot be accessed unless you are registered, which cannot be done online !!
Unless anyone can X reference it in another catalogue I can't do anything until contacting them tomorrow.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Post Reply
