Good on 'yer Paulcitroenxm wrote:Oh ok then... go on.. you twisted my arm!!
Guess the Rack !!!!!!!!!!!!!!!!!!!
- KennyW
- My Cars: Current Citroen's
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Xantia 2.0 90hp estate
Xantia 1.9 TD estate - x 132
Paul and Jim,
As usual the forum comes up trumph
I have to check it is the inner ball joints but will check if weather holds over next few days and find out the cost of the parts my thinking is change both
I was concerned about removing the whole rack just to change the inner ball joint/s but if it can be done insitu thats great.
I will speak to my friend who owns a garge and get use of his ramp to do the job
I will also take some photo's for the forum.
Kenny
Kenny
C5 x7 2.0 HDi 160 hp Estate exclusive, the newbie
C3 1.4 petrol (SWMBO)
does your freinds garage roof leak when it rains thenKennyW wrote: I have to check it is the inner ball joints but will check if weather holds over next few days and find out the cost of the parts my thinking is change both
Kenny
if you post the last8 digits of you chassis/VIN No. i will get you the OE price and part No.'s,
as you can then aim them at a factors to cross ref,
regards malcolm
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
The rods are ONLY around 16 quid EACH! I get them off the Bay, cheap enough and good enough on there!!
I ramp may not help you too much as access from under the car is not possible due to the subframe being in the way, wheels obviously have to come off to... mind you, I guess you can have the car at the desired height to stand up to do it rather then lieing down like I have too...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
'13 3008 1.6 HDi GripControl - x 996
I had one changed on mine earlier in the year - discussions etc here: http://www.frenchcarforum.co.uk/forum/v ... hp?t=34756
Can't see how you'd do it without taking the wishbone out, unless you have got one of these over the rod tube spanner jobbies...
For reference - track rod end play can usually only be felt with with weight on the wheels in normal - in high the angle locks it out. I could still feel the play in the inner joint in high. Car feels and sounds much better with it changed!
- x 54
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Hi All,
I have removed the inner track rods from my 1.9TD rack and since they are different track rods for my HDi they will be available to who wants them.
Kenny
Kenny
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Hi All,
I've just checked the service citroen site and the track rods are the same for both 1.9TD and 2.0HDi 90hp
Part nos 3817 41 left & 3817 42 right
Kenny
Kenny
- CitroJim
- x 6183
- Contact:
One of these look like the kiddo you need..RichardW wrote: Can't see how you'd do it without taking the wishbone out, unless you have got one of these over the rod tube spanner jobbies...
Bit pricey though unless you are doing them regularly...
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
I think the bike chain tool is the option
Kenny
Kenny
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Hi All,
I've checked the steering rack and there is no movement at the outer ball joints and the inner ball joints but icould feel the movement still coming through the rack.
I checked the pinion for any play nothing.
I checked the universal joint above the pinion and there is some play there
Has anyone had play there and this is where the fun part starts how easy is this to change
Kenny
Kenny
- CitroJim
- x 6183
- Contact:
It's not too bad a job to swap it Kenny. Easier than inner balljoints. Access is a bit tight but not too bad really.KennyW wrote: Has anyone had play there and this is where the fun part starts how easy is this to change
The worst job is to drop the steering column inside the car. In addition to the UJ on the top of the pinion valve, there's another on on the end of the column under the dash.
Basically, remove the under dash trim, disconnect the ignition switch wires, stalk wires, airbag/wireless remote wiring and any other wiring in the way, then undo the lower UJ bolt, undo the four nuts holding the column and carefully drop it as you disconnect it from the UJ.
Under the car, undo the UJ bots on the pinion valve and pull it clear and out, leaving the stub of shaft in the big rubber grommet...
Reassembly is a reversal of disassembly. Be careful to do the dismantling with the steering straight ahead so that when you reassemble you know where to position the wheel.
