citroenxm wrote:As you found cutting the wires wont help, you need to physically remove the plug.. this is an S2 car, the plug is held on by a "Slide" up lock plug... get a small screw driver and lever it UPWARDS, as it levers up the plug pushes away... Its the same setup as the Main loom harness that goes through the inner wing on the (UK CAR) Drivers side at the front, OR if you have one, the Lexia 24pin plug for S1 xantias...
Paul
** EDIT: OOeerrrr I forgot this is a rear door problem, the door lock is virtually hopeless to get at.. Sorry if I didn.t help much...
