Found something strange behind the front bumper .
No not the neighbors cat ..
It plugs into the loom and is like a long plunger thing
My ZX Estate
- Huskyxantia
- Donor 2023
- My Cars: Past cars
Xsara Picasso 2019 to 2022 r.i.p
Xantia mk1&2 1.9D & 2.0Hdi
Peugeot 206 sw 1.4hdi
Other models
Skoda fabia,escort van,ford ka,Vauxhall astra g car & estate, Vauxhall corsa b, Suzuki swift
Escorts mk 1,2,3,4,5 fiestas mk 1,2, Sierra diesel mk1 Mondeo mk1 diesel .
Peugeot 207 , 307sw
Now cars
Picasso 2.0Hdi now gone to scrappie
Citroen zx estate 1.9D the cherished one
Peugeot 206cc raised from the dead & saved from the crusher traded up to a 308cc
307sw traded for the 207 .
Wish list.
Peugeot 405 diesel
106 or 206
Mondeo Mk1 diesel once owned 1.8tdi was real nice. - x 423
Re: My ZX Estate
Husky.
- white exec
Re: My ZX Estate
Image won't open...
Plugs into the loom? Could it be a shuttle, part of a warp drive system?
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
Re: My ZX Estate
To infinity and beyond.
I'm having trouble uploading my photos ,it my mobile being a pain .
Husky.
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
Re: My ZX Estate
Its called a Dim-dip system
Resistor and there's a relay in line as well, my one is smashed and rotten ...
Wonder where they can be purchased
The dim dip relay is supplied with current from the side light circuit and energised from the ignition being switched on, it allows battery voltage to pass through the resistor to the headlight dipped beam circuits.
It lights the head lights one sixth of there normal power so the car can't be driven using side lights Alone.
OK, so that's why my side lights work on there own because my part is broken and rotten !!
This was law a while back ... How things change
Husky.
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4920
Re: My ZX Estate
You can legally bypass it now.
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
Re: My ZX Estate
My side lights work
Headlamps and main beam.
Its not plugged in as I pulled it out the socket .
How do you bypass it
Husky.
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
Re: My ZX Estate
I did read Vauxhall bridged the plug wires as they were catching fire , that was a while back.
Husky.
- white exec
Re: My ZX Estate
Dim-dip is a bit historic nowadays, but made sense, particularly in daylight-limited territories. A predecessor to daylight running lights.
Running high-wattage devices through a resistance (eg cooling fans, blowers, headlights) isn't very clever, as the dropper resistor needs to dissipate lots of power (heat).
Much better IMO is to run two devices in series-parallel. This is now standard practice for twin cooling fans, and can also be done for dip-beam headlights. All that's needed is 3 relays, and there is no wasted heat generation,
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
Re: My ZX Estate
Checked the lights last night after putting front wings back on , all working I'll have to tape up the socket which the resistor used to be plugged into just to keep water out.
Husky.
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
