what spares fo you need i have a full bodykit a set of wheels. lots of other bitsbxzx16v wrote:A small update on life with the Zx , I thought I would give it a run on Thursday , so after refitting it's bosch battery back on it fired up without a hitch . I set of for work a good 1/2 hr before I normally do and had a cracking drive over to Langsett to stretch it's legs and once fully warmed up opened it up to blow the cobwebs off, I forgot how lively this little car is and once over 4000rpm it really does come alive . I think I will be using it a couple of days a week for the work run now that the roads are better . I have also come across a Zx16v which is being broken for spares so I may have a look at this and get the 16v specific parts off it ( or as much as I can fit in the doblo ) which will be quite alot , I will probably come away with the bonnet and doors too which I can store in the shed , I'll post up what I come across .
Mark
I shouldn't think so, not until we run out of petrolbxzx16v wrote: Your not thinking of turning to the dark side are you Luke ?
Mark
