c5 2.0 hdi does the egr valve give much trouble?
Hi
I get a shuddering through the car (mainly on cold starts) that only smooths out above 1000rpm. Previously I blanked off the EGR with a plate from ebay, this solved the shuddering but put the Engine Management Light on (2004 2.0 hdi) so I removed it again.
RE the EGR valve, does it open or close at 1000rpm and does the vacuum pipe from the solenoid suck it open or suck it closed ?
I have 20"hg vacuum on the pipe at tick over which alters when revved, then settles back at 20"hg does this sound right ?
- x 9
Johntom
Based upon your description of what you have done and seen the logical conclusion is that the EGR valve is stuck open or partially open.
The vacuum will drop as demands are made on it but as long as it comes back to about 20 inches irrespective of revs it shouldn't be a problem.
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
- x 9
Well without knowing how the engine is mapped one can't be 100% sure but I believe that at 1000 rpm the valve will be closed or very close to being closed.johntom wrote:Hi
so should the vacuum be there from start up and should the egr be closed until 1000rpm?
Also do egr valves tend to fail mechanically or is it likely to be full of carbon etc ?
many thanks
I personally have never seen a stuck EGR valve so can't comment from first hand experience but based upon what others have said the EGR valve will certainly have a degree of carbon coking and it may be this that is causing it to stick but other unspecified mechanical failures appear to happen as well.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
