No worries, I've enjoyed myself, glad I could be of help
The balljoint that wouldn't quite go right up its taper is an odd one. Theres no burrs and both surfaces are smooth. Also, the amount of thread available on both sides when torqued up is exactly the same so we're tempted to say that its just a slightly malformed dust cover. Toby's going to keep an eye on it though just in case.
That 3/4" torque wrench is quiet something
As Toby says, we had some fun but with a bit of sideways thinking we got there
Just got back actually, had a bit of a snooze half way. Other than the that break, I made good time. It was an excellent ride out for the XM!
Hub reassembly confirmation
- x 54
'13 3008 1.6 HDi GripControl - x 996
3/4" drive torque wrench...nice! Good work on getting it back together lads.
I usually just nip the hub nuts up on the stands, then drop it on the floor, and do the final torque last thing (I also crack the nuts before jacking it up). You can't do that if it's got centreless wheels mind, and on my mate's C5 it was a bit of PITA as the alloys didn't allow removal / refitting of the nut clip so it had to be jacked up and down twice
That we did, I still can't get my head around how those allen keys withstood the abuse!red_dwarfers wrote:As Toby says, we had some fun but with a bit of sideways thinking we got there
RichardW wrote:3/4" drive torque wrench...nice! Good work on getting it back together lads.
It certainly is nice. Light work of driveshaft nuts and balljoints. Jim has seen it and wants one. Think it goes up to 410 ftlb.
You're right, centreless wheels are a problem, as are the wheels on the Coupé which are offset a bit to clear the Brembo calipers. The clip can't be removed and the nut is buried.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
Malcolm, we did a very similar thing.citronut wrote:if/when i cant get to the hub nut with wheel on, i remove the wheel stick an old heavy screw driver into the web of the vented disc,
fit two wheel bolts to stop the disc trying to move on its retaining screw's,
this locks the drive flandge whilst you undo/do up the hub nut,
regards malcolm
I had an allen key which we used on one side. It made it to 325Nm with marks, however it sheared when attempting the second side. I did find another though that did the second side and came out with no marks at all!
We also found that I have an even thicker allen key should I need to do it again. I did re use the old nuts as they were different to the new ones. The old one is a flat nut with a spacer behind it. The new nut has a shoulder behind it, is this in place of the spacer?
Toby
Previous:
Previous:
Thanks Jim.CitroJim wrote:Pleased all is back together again Toby
What'd the news on the Caliper Front?
Calipers will take some time. I don't think I have a choice but to split them. I'd like to find a way of preventing the corrosion again but not sure how really. Only problem with splitting them is seal kits are £40 per caliper although whether seal renewal will be necessary I don't know.
Toby
Previous:
Previous:
£40 quid for calliper seals?????
here is price and part No. for all the three seals required for one calliper,
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
96025615 PISTON SEAL 2.17 GBP 2.60 GBP 2.60 GBP
96025613 PISTON SEAL 1.76 GBP 2.11 GBP 2.11 GBP
95587148 PISTON SEAL 1.40 GBP 1.68 GBP 1.68 GBP
if you send me the last 8 digits of you chassis/VIN No. i will check specificly for your car,
regards malcolm
these are the main presure seal, the piston dust seal and the small seal that sits between the two calliper half's,
regards malcolm
regards malcolm
regards malcolm
No problem Malc.
Update on the calipers
I've come across a company in Wales that can strip them down, clean them up, bead blast them, and then rebuild and paint in any colour for £75 a caliper. It does mean sending them away and paying for P&P back (£15). Could probably also supply my own seals as they want a tad too much for them.
Good opportunity to have them painted a colour other than black. I'm thinking silver at the moment, or possibly blue to go with the car.
£75 seems fairly reasonable to me but then I don't know. Thoughts?
Less work for me to muck up
Have just realised I will also need to modify the brake pipe brackets as the braided hoses are slightly different dimensions. Nothing is ever easy eh?
Toby
Previous:
Previous:
