Xantia stiff rear suspention
- Xaccers
- x 184
Zohar, have you corrected the ride height at all?
DIY sphere tool
DIY sphere tool
- My Cars: Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD - x 8
In one of my previous post at this thread I mentioned that the new rear anti sink sphere was manufactured on 2004 ( the manufacturing date is stamped on it ) I don't know if a sphere has a limited shelf life but I changed it with a new one that was manufactured on 2010 and it did a change, the car rear suspension is less stiff although not as smooth as it the front suspension. I checked if I should add Hydraulic ( LHM ) so I moved the manual height lever to the maximum height position and waited till the car height stabilized the Orange indicator float was above the two red rings. I added LHM and the beginning the Orange float moved down but before it was between the two read rings ( it was slightly above the top read ring ) it started to raise again and I wasn’t able to move it to be between the two red rings. Does anyone know what can be the cause for that
Zohar
Zohar
- Xaccers
- x 184
If the float is above the red rings, then you've over filled the lhm tank, which isn't a problem.
You may need to bleed your brakes and do plenty of citrobics.
DIY sphere tool
DIY sphere tool
