Citroen Relay 1.9 engine compatibility
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Thank you all so much for the help so far. Unfortunately, we're unable to get pictures of either engine (he has no internet access and is 600 miles away). I think he's going to go for the engine we've tracked down though (assuming courier quotes aren't too horrific).
Is there any obvious (and reasonably cheap) that could be changed while the engine is out? I thought a new clutch would be sensible but can't think of anything else....
Thanks again,
Rob
Thanks again,
Rob
The other obvious will be cam belt and water pump... Be a dream to do while on the flour... Change the cam seal behind the cam shaft sprocket tooo... Clutch a good idea if you may have to swap flywheels... Compare them both and check them...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Me again! Can anyone confirm that this is a XUD?
http://www.gumtree.com/p/cars-vans-moto ... cture-zoom
Lol.
Thats because its the inlet manifold Peter!! Its a N/a engine, and they have a larger wide plastic manifold ontop of the engine..
Thats a Correct Relay engine, but its NOT an XUD its a DW8... They are almost the same but there could be pump compatability problems, you would need to assume you have to swap the pump and flywheel as I said above... I think the DW8 engine is vurtually the same as the XUD... so I cannot see any problems at all...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
I'm sorry to keep dredging this up. My brother has bought an engine (an sold as a XUD 9 from a 1998 Berlingo with the D9B code) but the mechanic fitting it says that it won't fit because the mount on the cambelt side of the engine won't match up. The dead engine is in a 1997 Citroen relay. I have attached a couple of picture, one of the mount in the van and one of the cambelt end of the new engine. I'm baffled by this - I thought that a replacement XUD would go straight in but it seems not. Is this because of the way the engine in the Relay et al is mounted at a different angle? Apologies once again for the ignorance, unfortunately neither me nor my brother know an awful lot about this...
The above link is for the picture of the engine (RIP) in the van
This link is for the engine he has purchased and the mechanic reckons will not go in the van....
It will... That engine mount is completely removable from the engine and the relay mount will go in place of it.... Defo... It may look as though it wont but get voth engines side by side and it will start to fall together.... Well done. So far so good....
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
http://www.find-a-part.com/ is great for finding engines. Found me 2 engines over the last couple of years for different cars at good prices.
Just fill in the form then breakers will contact you with prices
2001 Citroen C5 SX 2.0 petrol - Misty Lilac
0-60 MPH Calculator - Android app - https://market.android.com/details?id=c ... zero60full" onclick="window.open(this.href);return false;
Weight Transfer Calculator - Android app - https://market.android.com/details?id=c ... ansfercalc" onclick="window.open(this.href);return false;
