right seems like weve solved the problem replaced the pipes between bulb and fuel pump with clear braided fuel line pipes we took off were very brittle
Car is now running fine still a few air bubbles but no where near as bad as there was .. just going to replace line from bulb going back to tank as that has also gone brittle
car stalling at 3000rpm
http://s143.photobucket.com/albums/r124 ... %20xantia/
Teresa
1996 Citroen Xantia 1.9 TDLX silver
2004 Honda cg125 red
Teresa
- Xaccers
- x 184
Excellent news!
DIY sphere tool
DIY sphere tool
- falling-out-with-my-car
- My Cars: Citroen C5 Aircross 8 speed Automatic, Flair Model with far to many toys and nice comfy armchair like leather seats. ha ha Ive just had a conversation with the car. setting everything up verbally
- x 24
running on filtered WVO I have gone through three squeezy bulbs in around two years they dont seem to like veg oil very much, in the end I invested in a fuel pump which now makes bleeding the filter at filter change time so much easier, the pump just fitted as a replacement for the squeezy bulb a non-return valve prevents the fuel running back to the tank like the vacumm of the squeezy bulb used to.
- Xaccers
- x 184
Wonder if it's the waste that does it, with the remains of those acids even after drying.
Not had a problem with Cassy's bulb and that's with what? about 5 years of SVO?
Come to think of it, the only fuel lines i've replaced were hard even before I switched to veg.
I am thinking about replacing the rest of her fuel lines simply because they're so old now.
DIY sphere tool
DIY sphere tool
i have never used wvo in mine ..it was always svo ...we started using it spring 2010 did not use it over winter but few days before we had the problems we did put in 60l of svo as we had to get over see my family .. then go to Peterborough to pick up my fellas Ducati it was 2 days later we had the problems with it
Teresa
Teresa
- Xaccers
- x 184
I think it's just hit and miss given the ages of our cars, most rubber components have gone hard by now so air leaks are to be expected.
Keep the car, you know it makes sense
DIY sphere tool
DIY sphere tool
