car stalling at 3000rpm
well think i have may have just found it ive covered the primer bulb and clips in clingfilm ran very lumpy for a few minutes and now i can rev it over for 4k and no stalling ... looks like a new primer bulb is needed £20 from GSF
http://s143.photobucket.com/albums/r124 ... %20xantia/
Teresa
1996 Citroen Xantia 1.9 TDLX silver
2004 Honda cg125 red
Teresa
will let you know what its like when i actually take it off just been for a drive in it and it seems fine
myglaren do you know if this would this be any good? have a chandlers just up the road from where i live
http://www.mailspeedmarine.com/fuel-lin ... 7499.bhtml
Teresa
Teresa
- Dommo
- My Cars: Current
07 C5 VTX+ 2.2 HDi 173hp
97 S1 Activa
06 Boxster S
93 XM 2.1 Turbo SD
Previous cars
91 Toyota Soarer UZZ32 Active Suspension
97 S1 VSX 1.9 Turbo D
99 Xantia Activa
98 2.1TD Xantia
99 306 - x 19
Screwfix also sell them! They don't feel of brilliant quality but it's a Lazer product, and doing a fine job on my car currently.
http://www.screwfix.com/p/laser-diesel- ... tool/77865
I may be pointing out the obvious to you here, but it's worth mentioning in case you weren't aware (I'm sure you are though), they are directional, with an arrow on, you want the arrow pointing towards the fuel filter housing.
go for it, i had them on my boat, they lasted about 2 years but thats out in the sun and it was the one way valve that packed in but for £8 you cant argue.
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
ok got a new primer pump yesterday ... re bled system again and the car ran fine no hesitating ... got up this morning seemed to be air in system again primer bulb was staying hard ....but no where near as bad as there was ..went round and rechecked all the jubilee clips making sure they were tight and hey presto car started took it out for a bit of a drive not too far as didnt want to be a stranded female it ran ok just been outside again still running ok so will check again in the morning but everything seems to be ok
for now
not checked the old primer bulb but my fella said he blocked off both ends and when he pressed the bulb it was sucking in air
for now
Teresa
Teresa
UPDATE
ok car started straight away this morning no problems revved it a bit seemed fine Got about a mile down the road car started to misfire and came to a stop where it was managed to roll it onto the curb... lifted bonnet pressed primer bulb a few times and it started again turned car around as no way was i risking outer ring road in norwich at rush hour it started and misfired 3 times as i was trying to get it home .... went to work on my bike came back car taking ages to start again but once started its revving fine no misfire even been for a drive around the block dont know where else to look now any suggestions
Teresa
Teresa
- My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon - x 231
If those symptoms persist, there's probably another air leak somewhere to be cured. If not, it's just residual air being purged that was still in the system.
If you're willing to risk more test drives, I would let it idle up to normal temperature then take it for a sprint through the gears. Any air ingress should be apparent within half a mile or less, IME.
From past experience long ago, I'm always wary of the seal achieved using tiny jubilee clips, say on pipes less than 3/4" dia. Used to find on tightening that the worm thread part stayed rigid, and thus the clip itself became non-circular. Further tightening seemed to make things worse. Just a thought.
As Mike suggests, maybe a leak elsewhere?
Martin
1995 Xantia TDLX (deceased )
You raise a good point there Martin, it's also essential to use the right size jubiless clips as too large and they won't seal.
Many despise the clic-clips used by PSA as I did initially, until I got the proper tool. Now I prefer them over jubilees, so much quicker to use and always makes a secure seal.
so doing my head in now really cant be bothered with it
anyone want to buy a xantia
Teresa
Teresa
- Xaccers
- x 184
Candy, head to B&Q, buy some clear pipe and run it from the primer to the fuel filter and some smaller pipe from the filter to the pump.
There are so many places air can get in, the primer-filter pipe, the thermostat at the bottom left side of the filter, the o-ring between the filter and heat exchanger, the filter lid, the elbow that comes off the filter lid, the size adaptor on the way to the pump and then the banjo on the pump itself.
Without clear piping you won't be able to diagnose the issue properly.
DIY sphere tool
DIY sphere tool
