Hi thanks for the help i have just replaced both the rear arm bearings and at least they really did need it the wheels now sit straight and the car drives fine Although the steering now pulls to the right (I think the alignment is out) The 1st arm took about 1 hour to get to bits the other 1 only took about 15min once i found out that i didn't need to take so much stuff off ... However one the first one i did remove the brake pipe and found that there was little problem with the nut and the bleed nipple as i was given a nice set of self adjusting spanners that grip anything..
thanks
j.j.
Magic carpet? Ice skater? or Death Trap
