Cold idle problem - Xantia 1.9TD following use of BioDiesel
- Donor 2023
- My Cars: 2013 Peugeot 3008 Allure 1.6HDi - FD63 FWA VF3**************[VIN obfuscated, can be read by forum staff]
1995 Citroen Xantia 1.9TD S1 - M728 GDL VF7**************[VIN obfuscated, can be read by forum staff]
1996 Citroen Xantia 1.9TD SX S1 - N707 MGP (Currrently laid up)
2000 Citroen Xantia 2.0 HDi S2 - X435 JGJ VF7**************[VIN obfuscated, can be read by forum staff] (Clutch died Dec 2017 - Resurrected Easter Sunday 2021)
1997 Citroen ZX SX TD - P788 AJL
1959 Landrover Defender S2 - Two owners from new
1968 Triumph Vitesse Convertible 2.0
1980 Ford Escort RS2000 Customer - 2nd Owner
1988 Saab 900 T16S - A 1980's exercise in understated Hooliganism...
Oh! and two Harley Davidsons - A 1990 Sportster and a 2003 Fatboy 100th Anniversary (the only vehicle I have owned from new) - x 81
I have uploaded two videos to YouTube for the benefit of everyone once a resolution is found - hopefully!
First one is the initial Cold Start yesterday (around 3 minutes 32 seconds)
Love the comment I made at 56 seconds in retrospect! Looks like a pump and injector rebuild may be in order.
The video below is of the fuel filter as removed. You will laugh with amazement, I'm sure! (1 minute 10 seconds)
Forte Diesel Treatment although the best on the market has not yet resolved this despite being held at 5000rpm.
I am going to clean up the tank sender as DickieG and others have suggested.
- Xaccers
- x 184
My god that filter looks manky!
Did it just fall apart?
Even when I've left Cassy's in too long that it got to the stage where I couldn't rev above 2000rpm when cold it wasn't that bad!
DIY sphere tool
DIY sphere tool
- Donor 2023
- Donor 2023
Not good advice at all. If you are caught with or traces of red having been used in the past in your car, the fine is all the duty for all the fuel they can either prove or estimate you have used since owning the car and probably a £1000 fine on top so you would not be better off especially if you get a jail sentence too and end up in a cell with someone that likes the look of your ass!robert_e_smart wrote:If you're too tight to use white diesel, use Red, and maybe be prepared for the the 1 in a million chance of being caught by VOSA. You'll save more than the fine or the value of your Xantia and not have any running issues!
- mongoose100
- Xaccers
- x 184
Was that while it was in the filter housing or did it come out as one piece?Rhothgar wrote:Hi Xac
Once I had taken the top of the Fuel Filter, I put my finger in the hole, as you do, to take the filter out and just the metal came out.
I would say the bio destroyed the glue holding the filter together.
The worry would be if anything managed to get to the pump side of the filter housing as it disintegrated, however as the hunting clears when the engine warms up it would suggest that isn't the case.
What diesel do you use? When I'm caught low away from sources of veg I use shell v-power, it's more expensive than normal derv, but comes pre-mixed with redex-type cleaner and has more oomph.
DIY sphere tool
DIY sphere tool
- Xaccers
- x 184
Diesel for agricultural use has a lower duty applied to it, but to stop people using it in cars, they add a red dye.mongoose100 wrote:Sorry to head off subject here but, can someone please educate a poor New Zealander on what "Red" and "White" Diesel is??? We just have one here, a rather yellow/brown colour...
Cheers guys!
This stains the fuel system, not a problem for tractors, but for road use it is still detectable long after the last tank of red was used.
The dye can be removed illegally, but in doing so it removes some of the lubricating properties which isn't good for the car.
DIY sphere tool
DIY sphere tool
- mongoose100
- Donor 2023
It was in the fuel filter housing like that. Doh!
- Donor 2023
- Xaccers
- x 184
Sorry, sedative after having a wisdom tooth out yesterday is making me forgetful, meant to say you'll need new jubilee clips (small ones) to reconnect the fuel pipes on the sender unless you're good at reusing the press clips, and cable ties are handy for stopping the fuel pipes slipping down beside the tank out of reach.
Lift up the rear seat, pull the plastic panel directly up off it's studs, and fold back the carpet.
There's a large rubber circle with a slit by one edge.
Use a large flat bladed screwdriver in the slit to pop the rubber out.
The sender is held in place by a large plastic screw on seal with ridges to help spin it off.
Use a bit of wood/large flat screwdriver to press on a ridge to get it going then you should be able to unscrew by hand.
If it's really tight you may need to apply a hammer to the other end of the wood/screwdriver but go easy as you don't want to crack it!
Put a cable tie around each pipe if you think you need to, or tie a bit of string, and pop them off the sender.
Unscrew the seal and withdraw the sender.
On the bottom there's the removable mesh screen, pop it out and give it a clean.
DIY sphere tool
DIY sphere tool
- Donor 2023
Cheers for that Xac.
Of course, we all have an extra hour of daylight now so I should still get this done today.
I did see the edge of the plastic disc but was not sure if that was it so your reply has clarified well.
Wisdom tooth, eh? OUCH! I'm lucky not to have had any out so far. What was the drug of choice? Morphine? I detest the stuff. Once had an operation which required large doses of the stuff and when I came round. I sat there in the hospital bed with the curtains drawn around me wondering if I was still alive - it is quite a strange level of consciousness, even after being awake for several hours and having had a conversation - still thought I had died.
Of course, I thought to myself I'm already dead so there's nothing anyone can do so no point making a fuss. Very bizarre indeed!
- boeingmech
- My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon - x 232
From a cold start, the idle should be raised to about 1100rpm, that doesn't seem to happen?
Secondly, I suspect you've got one or two duff glow plugs and/or some air ingress as it should have started on first crank. The glow plugs will remain active after starting for a minute or so (unless you raise the rpms as if driving off) to reduce cold idle smoke.
You said you didn't use any throttle which is right, the governor will have it wide open for you until the engine actually starts anyway so there's no point.
I would, as a matter of course, check the air filter while you're at it and a change of oil (plus filter) wouldn't hurt.
- Xaccers
- x 184
It was a diazepam derivative I believe, I remember telling the sedatition about my phobia of plasters, an eye protector being put on me and saying thank you, saying something hurt, and then coming around in the recovery room to then see CitroJim arrive to take me and Danielle home.
DIY sphere tool
DIY sphere tool
