c5 front brakes
411514
(Donor 2017)
My Cars: Citroen C5 2.0 Hdi 2003
x 39
Post by 411514 »
if you have access to a welder then you could weld another nut onto the end of the bolt and then unscrew as normal
Kowalski
My Cars: Ex 05 C5 2.0 HDI Exclusive 145k
Ex 97 Xantia 1.9TD SX 144k
Ex 94 Xantia Dimension 1.9TD 199k
Post by Kowalski »
citronut wrote:Kowalski
yes i know this and it was the T40 that died :wink:
i did also phone round the local factors asking if they had or could get me a T40 especialy for brake callipers, most of them saidthey had never heard of such a tool,
its funny how a few years ago i was told by a motor factors that the T40 is not coverd by the life time warenty, as people use them to undo calliper bolts that are very tight,
regards malcolm
I'd heard it was because of some torx bolts which secured calipers on transit vans, they had threadlock on them...
I'd also seen people selling boxes with 20 T40 bits in them... they're a disposable.
daviemck2006
My Cars: Far too many good ones to remember. Many BL, Vauxhall, Ford, Renault, Citroen, Peugeot, and now VAG
x 488
Post by daviemck2006 »
Well at last c5 mobile again, new pads and discs fitted. once I had the correct pads got the first side back together in no time, went down the garage, he removed the locking nut on other side in 5 mins, back up road and did second side no problem. Just need the replacement trolley jack delivered and to get 4 wheel studs and the job's a good un!!!!!!!!
Skoda Karoq 1.6tdi 2018
Citroen relay camper 2012
In the family
Seat Leon 1.5tsi tourer 2019 daughter 1
C1 vtr+ 2010 daughter 2
My Cars:
x 92
Post by citronut »
theres one reason not to use halfrauds unless your realy stuck when the propper motor factors are closed :wink:
regards malcolm
Monkeyfeet
(Donor 2022)
My Cars: C5:Hatch & an Esatate. Real cruisemobiles.
Post by Monkeyfeet »
Got to get a rear suspension change done on a xsara today then I can have another go at the C5 front brakes. Getting them working again would be nice. I'm going to try bleeding them engine off so as to hopefully have the ABS not interfering. Not sure why it's being such a problem really.......
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
daviemck2006
x 488
Been away for a few days, c5 going well, I had no probs with brakes, when screwing in pistons had pipes clamped and once all connected bled them, basically 2 or 3 pumps and everything perfect. Hope you have yours fixed now
In the family
Monkeyfeet
(Donor 2022)
Just got back for a few hours myself this evening. I improved the brakes a bit by bleeding them last Sunday but I'll be using the C5 to get down t' south coast tomorrow. I might be taking it easy...
Post Reply
