differnce between bx suspanstion and the xantia. And ADVICE
My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars.
x 1207
Post by Peter.N. »
I wonder if the difference in 2.1 engines is the EPIC pump because all my XMs have had mechanical Bosch pumps and all pull well and smoothly from very low revs. The Hdi pulls well if you put your foot down hard but you can feel vibration until 1500 rpm thn it stops, its not severe but not smooth like the XM. I don't think that the engine is vibrating excessively but its being transmitted to the car.
Citroenmad
My Cars: 07 Citroen C6 V6 HDi Exclusive - Red
07 Citroen C5 HDi VTR - Red
09 Citroen C3 1.4i VTR - Silver
01 Citroen Saxo 1.1i Forte - Mango Orange
93 Ford Mondeo 2.0i GLX
19 Hyundai i10
x 110
Post by Citroenmad »
Our Xm is also Bosch and does pull well low down, but the HDis seem better, more pull even lower down the revs.
Not sure why your HDi doesnt like pulling from low revs though.
19 Hyundai i10
citroenxm
My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising
x 71
Post by citroenxm »
Wow, I dont get any vibration either, only when im in 5th at 40mph... and thats ONLY my car... mums car, her new one and another I sold a while ago were all sound and smooth....and quiet!
Paul
A very sad...
1994 XM 2.1 d auto
My Cars: MK2 '17 C4GP 1.6 BlueHDi 120
'13 3008 1.6 HDi GripControl
x 1002
Post by RichardW »
My HDi 110 Xantia is noticeably smoother and pulls better at <1500 rpm since I changed the cambelt. Timing was apparently bob on both before and after the new belt was fitted, but it definitely feels better :?
HDi 110 is leagues ahead of the 1.9TD - I can't imagine going back to a Xantia 1.9TD now - I might have a ZX TD on veg if the cost of dino diesel keeps soaring :evil:
citroenxm
x 71
Post by citroenxm »
RichardW wrote:My HDi 110 Xantia is noticeably smoother and pulls better at <1500 rpm since I changed the cambelt. Timing was apparently bob on both before and after the new belt was fitted, but it definitely feels better :?
My thoughts exactly Richard, Ive kept my 1,9td SX Xantia of 1994 vintage, for BIO reasons, and also she has my plate on her too....
Paul
A very sad...
1994 XM 2.1 d auto
My Cars: Currently:
x 1207
Post by Peter.N. »
5th at 40 mph is the sort of speed I'm getting vibration at, or less than 30 in 4th, you can hear it as much as feel it, but the XM doesn't do it, maybe I'm expecting to much. The Hdi pulls well but it has the feeling that the flywheel isn't heavy enough.
Citroenmad
19 Hyundai i10
x 110
No, thats not right Peter, they shouldn't do that. Our 110 HDis are very happy pulling away from 40 in 5th and 30 in 4th. No problems, no vibrations and they pull well from that too.
My 138 will drop to almost tickover in 6th and pull away strongly without me having to change down! On the level mind, but still ...
You dont get that with a 2.1, Bosch or not!
19 Hyundai i10
jacksun1987
My Cars:
Post by jacksun1987 »
i must have on of the best 1.7td engine around. I put it in 5th at 30 at 1000rpm still pulled i evern left it in 5th. With out any revs and it still was on tick over.
Dommo
My Cars: Current
07 C5 VTX+ 2.2 HDi 173hp
97 S1 Activa
06 Boxster S
93 XM 2.1 Turbo SD
Previous cars
91 Toyota Soarer UZZ32 Active Suspension
97 S1 VSX 1.9 Turbo D
99 Xantia Activa
98 2.1TD Xantia
99 306
x 19
Post by Dommo »
Xac wrote:Imagine two self flushing lavatories, each with their own cistern fed from a single tank, but with an overflow pipe between them, and each with an overflow to the drains.
The one on the left (power steering) is smaller so fills up quicker.
Once full water flows through the overflow pipe into the suspension/brakes cistern, so it fills faster than if it was just using it's own water supply.
Once both are full the water overflows to the drains (LHM resevoir).
Someone flushes the left toilet (turns the steering wheel) so the water level above drops, and is replenished from the tank's flow to the steering cistern, and via the the linking overflow pipe, the tank's flow to the suspension cistern.
A fine explaination, thanks Xac.
What's stopping you plumbing both pipes off a 6+2 pump into a T piece with the open end going to an FDV, then supplying the steering and brakes from that? Apart from the nightmare of the plumbing is there anything technically stopping you from doing that?
jacksun1987
My Cars:
i Could go to bob wilding. About the oil leak and see what he says. Bullwinkle said it means taken the engine aport to find it. Cost a bomb it will. Im a bit lucky in the middle of 2 good citroen services.
My Cars: Currently:
x 1207
Post by Peter.N. »
Citroenmad wrote:No, thats not right Peter, they shouldn't do that. Our 110 HDis are very happy pulling away from 40 in 5th and 30 in 4th. No problems, no vibrations and they pull well from that too.
I am finding the exact opposite, you can slow down to tickover speed with the XM and it will pull away smoothly, if I do that with the Hdi it complains until it reaches 1500 rpm, not severely in fact under light throttle you can hardly feel but if you floor it, it just feels as though its turning to slowly.
citroenxm
x 71
Post by citroenxm »
jacksun1987 wrote:i Could go to bob wilding. About the oil leak and see what he says. Bullwinkle said it means taken the engine aport to find it. Cost a bomb it will. Im a bit lucky in the middle of 2 good Citroën services.
XUD Common items for Oil Leaks:
Cam shaft seal behind the Top pully - cam belt off of course...
Rocker cover seal, even rocker cover bolts can rattle loose and let oil out.
Crank Seal behind crank sprocket bottom end.
At worse, oil sump gasket...
Tell tails can help.. which side of the engine is it dripping off??? Cam belt area??, lower engine mount??, between gearbox and engine??
Paul
A very sad...
1994 XM 2.1 d auto
x 1002
Post by RichardW »
Head gasket can let go at the oil gallery end and the oil pours out - this was the end of my first Xantia TD....
jacksun1987
My Cars:
Well if or when it goes it goes. Battrey not charging as well. The light comes on after standing in traffic for about 5 minites standing. Could this be the battery or the alternater.
It still starts up first time. Evern in the cold weather and leaving stuff on by accident. Like i left my radio on for 8 houres. Still started. But this last month now and againe the light comes on for the battery.
citroenxm
x 71
Post by citroenxm »
Altinator brush's...
Paul
A very sad...
1994 XM 2.1 d auto
Post Reply
