you realy cant adjust the hights without the car being up in the air, with all four wheels on the ground/ramp/s/level,
as the very slightest movement of the clamp on the anti roll bar will allter the hight by quite a bit,
also this action should be a very very last resort, after making 200% sure the hight correctors and linkage's are fully working,
were abouts are you
regards malcolm
Xantia - Hard Ride
- Donor 2023
- My Cars: 2013 Peugeot 3008 Allure 1.6HDi - FD63 FWA VF3**************[VIN obfuscated, can be read by forum staff]
1995 Citroen Xantia 1.9TD S1 - M728 GDL VF7**************[VIN obfuscated, can be read by forum staff]
1996 Citroen Xantia 1.9TD SX S1 - N707 MGP (Currrently laid up)
2000 Citroen Xantia 2.0 HDi S2 - X435 JGJ VF7**************[VIN obfuscated, can be read by forum staff] (Clutch died Dec 2017 - Resurrected Easter Sunday 2021)
1997 Citroen ZX SX TD - P788 AJL
1959 Landrover Defender S2 - Two owners from new
1968 Triumph Vitesse Convertible 2.0
1980 Ford Escort RS2000 Customer - 2nd Owner
1988 Saab 900 T16S - A 1980's exercise in understated Hooliganism...
Oh! and two Harley Davidsons - A 1990 Sportster and a 2003 Fatboy 100th Anniversary (the only vehicle I have owned from new) - x 80
Did you get this sorted in the end, StevieM?StevieM wrote:!st shows a portion raised from chassis...I dont have that.
2ns shows measurement up to the bottom of the "cup" holding the rubber mounting.
If I take the 1st option actually onto the chassis that the mount is bolted to, it is 415mm (making my "L2" 140mm...out of spec, as '95 model should be 121mm) if I take the second option...it is 395mm.(ie making my "L2" 120mm...in spec)
I did mine yesterday and believe I have interpreted the manual correctly.
The 1st picture is skewed. The measurement is taken from the ground to the underside of the box section (that supports the boot floor) behind the rubber mounting.
415mm may be OK depending on tyre size. I think you may be misunderstanding the equation unless the Haynes BOL has misprinted it wrong.
I am running brand new Michelin Energy Savers (185/65/15). The centre of the wheel above ground on my Xantia measured 293mm. with 30psi. I added 136 mm. to this to get 430 mm.
Conversely, the front centreline is 286mm. due to the heavyweight of the front end crushing the sidewalls more. I took 121 mm. from this to get 165 mm. so mine is marginally high at the front.
Settings should be:-
Rear:- 420mm +7 or -10 tolerance.
Front:- 155mm (160mm. 205/55/15) +7 or -10 tolerance.
Hope this is of use.
My suspension still doesn't feel as wafty as a BX but I understand Xantias run tighter anyway.
