C5 Headlamp washers
Michael Paul
New User
Re: C5 Headlamp washers
Post by Michael Paul » 23 Apr 2013, 18:19
The headlamp washers aren't working tho, every time I go to operate them it blows a fuse in the engine compartment?
Ben82
Post by Ben82 » 23 Apr 2013, 20:04
Michael Paul wrote:The headlamp washers aren't working tho, every time I go to operate them it blows a fuse in the engine compartment?
Something most likely will be shorting to ground, the "fun" part is locating what or where is shorting to ground.
The following video maybe of help: http://youtu.be/TZrCrBx4uFY" onclick="window.open(this.href);return false;
He uses a special circuit breaker and test light to not waste a load of fuses trying to locate the issue. If you want to embark on finding the short yourself and need the wiring diagrams, then post up the last 8 digits of your vin, and one of us with Sedre should be able to grab the right ones for you. (Unless its an x7, as if I recall those diagrams don't show up properly in the current version of Sedre)
