FFS fella calm downfalling-out-with-my-car wrote:Howie are you asking me or telling me???? exactly when did I mention the thermostat in the above post? you brought that up,not me so who's not being correct now??? besides you said "it was a bit of a pain" your way.
whats the matter fed up because you took your knuckles off fitting yours to the back of the engine? I like many others have very large hands I don't know why I bother sometimes what difference does it make you wont get any decent heat until the stat opens anyway, 1 or 2 mins doesnt really make much difference the fuel pump return lines start to raise the fuel tank fuel temperature within ten mins. so no help there then.
Heat exchanger or no you still have to start on cold oil, the secret is fitting a 4 to 7 psi facet pump because heat exchangers on xantias increase the distance that fuel has to be dragged by the fuel pump unaided, fitting a facet pump stops the mechanical pump from struggling to drag the fuel the extra distance and causing a vacum inside the the heat exchanger introducing air into the fuel line when cold this also stops the cold engine hunting on cold veg oil, no facet pump eventually a broken fuel pump that wont suck fuel up to the engine hot or cold. I'm not going to argue with someone who obviously can't be given the easy way to do something or wants everyone else to do it his way. theres no,pleasing some people, I even bothered to check the internal diameter of the oil cooler lines 12mm. the outside diameter is 18mm. maybe it just racks people off when they realise your paying next to nothing for fuel.
I was talking to romie not you, its his car let him make his own mind up.
afterall he did ask for an easier way to do it, the oil cooler is behind the oil filter. as for being correct Ive done it matey and spent most of last summer sorting out all the issues brought on by fitting a fphe. as I said above the HE gets nice and hot very quickly. Im glad I don't get this kind of critizism on the veggie website esspecially when I dont even mention something someone accuses me of not being correct about. hey ho theres one born every minute;.
Sorry that you thought that I was questioning your reasoning. I wasn't sure if you had found a water pipe that heated straight away, you read more into my post than I intended.
I am trying to pass on some information, as I have previously connected my heat exchanger to the oil cooler and decided afterwards I'd prefer to have it heating the oil before the thermostat opened. Been their, done it and have the T-shirt, 100,000 miles of bio fuelled miles on numerous cars.
On really cold mornings my previous 1.9 td Xantia would take up to 5 miles to get up to temp, this is a long way when running on cold WVO.
Everyone has their own ideas and own ways in which they tackle problems, I try to listen to all ideas and make my own opinion based on sound judgment. Apologies if I have upset other forum members, there is no intention to wind people up whatsoever.
Howie
