with both wheels off the ground you will need to lock/hold one wheel to get the other to drive, one side then the other,
were on the south coast im in St Leonards on sea,
regards malcolm
XM no drive problem - please help!
- mongoose100
I'm guessing the syncro's are allowing the 'box to spin up to speed (in a no load state) then box just slots into gear.citronut wrote:i agree with that Paul but why is he able to select all gears with engine running without pressing the clutch pedel down, as well as the lack of drive,
or thats the way i read it anyhow,
regards malcolm
Definitely not clutch in my view, as some sort of drive is getting to the speedo sensor which, if I understand fully, is after the gearbox output.
Regan.
2001 Citroën C5 V6
1994 Citroën Xantia 1.9TD
2001 Citroën C5 V6
'13 3008 1.6 HDi GripControl - x 1003
The speed sensor is on the RH driveshaft, so it does read silly speeds on wheel spin - or zero, depending on which wheel is spinning
No need to worry about jamming the wheels for test, just pull the handbrake on! In fact, if the OS shaft is broken, then it probably won't matter and there will enough drag in the brakes to stop the hub rotating.
