I like the bayonett fittings, they are lovely and look neat with no " i dunit meself" jubelee clips all over the place
I think it will have to be a 2.1 rad myself, from memory i think the 1.9td i saw was a no go.
D
Xantia radiator interchangeability
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Some one has too like them DEAN!!
YES I Can JUST read that!
There a sod pain when the Steel has rusted and the damm things JAMM in the fitting of the rad! And it DOES happen! Your stuffed them!
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
PUSH damm bloody hard untill the metal collar passes the Ridges were the Spring C clip pops on to hold it in place...
There a sod if they are not perfectly CLEAN and clear...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- CitroJim
- x 6182
- Contact:
As far as I can see, comparing one against the other, the late bayonet 1.9TD rad and the 2.1TD/Activa rad are identical in size and fixing lugs..
As for refitting, yes, spot-on Paul The problem is often removing them and sometimes, especially with the bottom hose it's necessary to break up the bayonet socket to avoid damage to the bayonet plug on the hose.
I've even gone as far as to remove the rad with the bottom hose still attached to give a better purchase on the job.
As you say Paul, get the bayonet clean, pop the special O ring off and descale it and then lubricate the whole bayonet, O ring and socket with a smear of Vaseline.
The Activa never had anything but a bayonet type, even in its earliest incarnations. As the top hose on the Activa is a bit of a special one, fitting a non-bayonet rad would be a game. I suppose you could do it with a joint in the top hose but you're just as well off using the bayonet.
Despite the joint looking a bit flimsy, if you're careful to avoid damage to the bayonet plug and clean and lubricate well, they're very water-tight...
Always apply silicone grease to the fittings, garanteed not to stick, ever.citroenxm wrote:PUSH damm bloody hard untill the metal collar passes the Ridges were the Spring C clip pops on to hold it in place...
Paul
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
