That's the stuff...brmartyn wrote: This stuff then?
That's a good price too
Would you use the whole bottle in one go?CitroJim wrote:That's the stuff...brmartyn wrote: This stuff then?
No the water is fine and always has been and the engine temp never goes above what it should beimperial21 wrote:Do you need to keep topping your water up in the engine ??
If not you dont need it !
I used the whole bottle of stop leak.
Fresh air all the timehobblerian wrote:I know this might sound a daft suggestion and probably the first thing you checked, but have you checked that your air flow is set to fresh air in and not re-circulate? Two of my friends have moaned to me that their cars have been constantly misty and both have been set to re-circulate. A simple slide of the lever cured it for them.
Hi,CitroJim wrote:Yep. Into the header tank. You may have to drain a bit of coolant off to make room for it. The bottle contains 500mL if I remember properly.brmartyn wrote:So the Forte Stop Leak would simply be poured into the radiator?
It's seriously good tackle...
If that is standard of curry carry out you get locally I would take it back
