My understanding is that providing it meets or exceeds the pollution standards that were in place at the time it was registered it is legal. The C5 even without the FAP will more than meet the required standard, everything else being good. Ergo it's legal and by all accounts the MOT people have never made any observations on those that have been modified.
Without doubt in my mind the best way of resolving this is to get the Injection ECU code modified so that the system works without it, there are companies that will do this and there are contributors on this site who have done this and would likely assist should you want to go that route.
It is my belief that one reason the 2.2 is so heavy on fuel is that the injection system is configured to keep the exhaust temperatures as high as possible just so that the FAP system will work with the minimum number of re-generation cycles. The 2.2 was one of, if not the first car to use this system and as such it was a work in progress at the time the car was put on the market hence the later changes. If this theory is correct there is probably a lot of scope in ECU re-mapping that would substantially improve the fuel consumption characteristics once the FAP is removed.
cachaciero[/quote]
Thanks for clearing up the legal issue cachaciero and because I do plenty of miles I think what you suggest is probably what I would like to do if I can find someone with the knowhow
[/quote]
