1.9d dw8 engine, is it possible to get timing worng?
Oldpug
My Cars: Peugeot 406 GLX
Audi A3 TFSI S Line
Mercedes SL320
(In the past,just about every old Peugeot you can think of.)
x 64
Post by Oldpug »
I second that Panason1c. and that goes for any other "fault" mentioned,if something was wrong it would take ages to start, smoke, knock etc. This engine is just a modified XU,they are bullet proof, but will not pull the skin off a rice pudding.
Just a silly question,you have checked the cable to pump to see if your getting full throttle? an extra bit on the pump lever can make a difference.
barrydoran
My Cars:
Post by barrydoran »
Good point about the throttle cable. When moving the lever by hand, rhere does seem to be a large amount of movement in the arm before the revs start to rise. Perhaps I'm misenterpreting having to push the pedal loads.
I guess that throttle dashpot thing could have sunk in, hence why its adjustable.
Cant check tonight, car isn't here.
Thanks for the ideas, keep them coming.
Barry.
spider
My Cars: Soon, I hope...
x 77
Contact:
Post by spider »
It won't be that (I think that's at the slow end to stop it stalling)
Get someone (or a length of wood etc) and jam the pedal down, engine off obviously ;) :D
Then go look at the cable on the pump, and check its fully pulled the lever, you do not want it straining though, allow a 1mm or so of play really.
Andy.
Post Reply
