Sphere Clicks!!
- Old-Guy
- My Cars: 2011 Grand C4 Picasso VTR+ 1.6HDi in Kyanos Blue
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - now owned by XanTom
1998 Xantia 2.1 VXD Estate in Mauritius Blue - R.I.P. (terminal tin-worm) - x 17
Re: spheres
Translates as "I don't know anything about Citroen hydraulics and I don't want to know!"mikep wrote:I took it to an independent garage and he said he couldn't change them because you need a special tool.
The accumulator sphere can be a bit of a pig to undo - the special tools being a big cold chisel and 4lb hammer! Full explanations elsewhere on the forum
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - after 11 years now owned by XanTom
Re: spheres
Sounds like he is the tool LOLmikep wrote:I took it to an independent garage and he said he couldn't change them because you need a special tool.
A non-Citroen garage will often shy away, and say they need specialist tools! Removing the sphere is like unscrewing an awkward edisson screw lightbult. Replacing the spheres is an easy job to do. You'll lose a little LHM fluid, so check the reservoir when the job's done. A Citroen symbol on the old sphere indicates it's the original part from when the car was manufactured. Sometimes you can find cheap spheres on the internet. If so, it's worth buying the two, plus the four corner spheres while they're cheap, if you're planning to keep the car.
Re: spheres
Good guide here:mikep wrote:Thanks for all the info it is much appreciated.
OOOP's I use the cold chisel method to remove tight rear spheres, I'm going to get one of those proper tools.
Regards
Howie
Howie
2006 Fiat Idea Dynamic 1.3 Multijet
2010 Renault Laguna Dynamique tom tom 2.0 DCI 130
C5 VTR 2l 8v HDI Estate 112000 miles gone
Kia Rio 2007 1.5 CRDI 62,000 miles gone
2001 Dodge Durango 4.7 V8 170,000 miles gone
1999 Ford Crown Victoria 4.6 V8 151,000 miles gone
Do NOT get one of those tools.
They are poor quality metal and not up to the job, they can't grip the sphere properly at all.
total waste of money.
get one from pleadies, they are exactly what the doctor ordered
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2006 C3 1.6 HDi SX,
1971 D Special
2006 C3 1.6 HDi SX,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4922
If you are concerned about the quality then they have genuine Citroen spheres for £33
I think that GSF have them for around £20 and they do international deliveries.
yeah i found on their ebay shop but i'm not sure is it genuine or not, i sent them a message anyway asking but no reply yet!myglaren wrote:If you are concerned about the quality then they have genuine Citroën spheres for £33
I am feeling smug and not bouncy
machine mart chain wrench £7ish and a length of thick steel tube (nicked a bit of my kids swing), sorted! just did front corner spheres, and practiced getting access to accumulator with the same tool, didn't seem like a problem.
wish I had flushed before though as I just read old-guy's point about filling new sphere up with crappy lhm.
edit to add, citroen dealer quote: £200 diy including tool -£65
