Today i dismantled security valve and another valve located just below the LHM tank not sure what it call, it's aluminium with 5 connecter.
I had both valve clean up, and blow all the holes and replace it's tube seal.
Install back and start car, no matter what the car won't rise at all (the front suspension only)
Rear suspension work fine low high low.
Appreciate your opinion what i should do next.
Help Needed for Xantia
- VertVega
- x 13
5 connector valve is called the anti-sink valve.canntan wrote:Today i dismantled security valve and another valve located just below the LHM tank not sure what it call, it's aluminium with 5 connector. ...
PS: I thought I was reading a post from another FCF user from Malaysia who was called "AbangCorp"
Welcome canntan.
- VertVega
- x 13
Check if the front plastic clip (also called as "dog bone") is disconnected (?).canntan wrote:... the front suspension still not rise at all. ...
It is shown in pic.below with number 6.
Be careful when you are working under the car! Car must be well supported.
VertVega,
Checked under the car all things intact ie dog bone and the long metal connected front and rear height corrector ok.
Try to adjusted the front height corrector but it's not rise at all!!??
Could it be the height corrector jammed that cause it?
Any opinion is appreciate.
Hope to get the cause of it.
Thank you
Thank you
VertVega,
Some mechanic told me to replace the front height corrector unit since when i adjust the front height corrector it won't raise nor sink.
So today i will replace the whole set include the dog bone and bracket since i bought it from used parts shop, and tested it by pulling it i assume it is not jammed and in good condition.
Hope it will work after replace it today.
