The front ball joint is screwed directly into the bottom of the hub, see this thread:Timmo wrote:Going to pop out in a mo and have a look around and see what bits are indicated so I know for myself, especially for the dust covers!!
Will get the tyre sorted as have a good mate with a wheel clinic and valeting centre, so that's fine, will have a look at the wires on the boot as had them open to do the rear light on the boot side last week, (that should be the brake light and the number plate lights,- are they both the same side or seperate??? )
Is it a new arb link or can you get the dust covers seperately?? Long shot but you never know!
Will go and look for the oil leak as the engines pretty dry, but did spill some oil from the filter on changing! Will have a look at the exhasut oveer the weekend too,
Is front sus ball joint seperate or like some of the older cars and one unit??
Have got till the 19th when the ticket officially runs out but will try not to use it till have it sorted!!
http://www.frenchcarforum.co.uk/forum/v ... ead#unread
The ARB drop link is cheap enough, try:
http://www.carparts4less.co.uk
It's basically Euro Car Parts, but cheaper. You're best off making doubly sure you're ordering the correct part because they're known for getting wrong parts (EuroWrongParts anyone?).
