LED lamps.
- x 4
Apparently it's some old British standard (related to the packaging, not the bulb itself), 477 and 499 are both identical H7.myglaren wrote:Anyone know the difference between 477 and 499? (Apart from 22 )
Used Osram Nightbreaker in my old Xanita a few years back - the only noticeable difference was slightly more light, more white.
I'm currently using Philips Extreme Power in my C5 - they are superb. Apart from being much brighter, they give different/better beam pattern, more light where you need it. Just need to be very careful not to touch the glass bit when replacing them - they are more compact than standard H7, therefore running much hotter, so any fingerprints and dust on the glass will significantly reduce their lifespan. My first set of H7's lasted just over 2 years (one bulb failed 5 minutes after getting through 2010 MOT). You can find them on Ebay for around £18 a set delivered.
Cheers,
GB
05 C5 VTR 2.0 HDI
115k
115k
- x 4
My new H6W sidelight LEDs arrived today - 5 SMD, no canbus. Ebay, £3.49, UK based.
Installed in half an hour (had to partially remove front bumper bar to get to the offside sidelight bulb), no canbus errors, so it seems sidelights are not connected to canbus.
They appear slightly brighter than regular H6W bulbs.
I hope they last longer than the standard bulbs - last set lasted only two months.
GB
GB
05 C5 VTR 2.0 HDI
115k
115k
Well, NOT HAPPY!GB wrote:I hope they last longer than the standard bulbs - last set lasted only two months.
World record: O/S sidelight LED lasted 15 minutes, NS just over half an hour - two short trips, and they are both kaput!
I'm pretty p***** off after having to remove front bumper bar and all...
Back to standard H6W then, will replace them day before MOT to make sure they work...
GB
05 C5 VTR 2.0 HDI
115k
115k
thats what i was thinking and why? surely the bulbs life is down to its self and the only outside affect the car itself could cause that that could kill a bulb is voltage spikes? if this is the case surely there is a major design fault with the lighting circuit.
Vibration could be an issue but not to an LED............
The XM is weraing the same rear bulbs that it had when i bought it around 7 yeas ago, the front were only changed because i fitted HID's
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
- Old-Guy
- My Cars: 2011 Grand C4 Picasso VTR+ 1.6HDi in Kyanos Blue
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - now owned by XanTom
1998 Xantia 2.1 VXD Estate in Mauritius Blue - R.I.P. (terminal tin-worm) - x 17
Can beat that:- when the Xantia's (Jan 96 reg) N/S/R indicator light went in 2007, I discovered it was the original bulb. How do I know? Because the muppet who fitted the towbar to the car when new didn't leave any slack in the wiring so I had to replace all the cable ties to make some slack - and the bulb had lost almost all the yellow coating. Also replaced the brake/tail light bulb as a precaution.Deanxm wrote:The XM is wearing the same rear bulbs that it had when i bought it around 7 yeas ago, the front were only changed because i fitted HID's
D
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - after 11 years now owned by XanTom
On the subject of HIDs, does anyone other than me see the fringe colours as a problem? What I mean is that, as your view of an HID beam moves laterally (as you approach an oncoming car thus equipped) the colour of the light can be blue or orange depending upon the angle.
Probably not an issue most of the time, but I have on occasion been convinced that I was being followed by a police car because the HIDs combined with a "sporty" suspension on a lumpy road gave a blue flashing effect.
I also nearly slammed on the brakes a couple of nights ago when an HID-equipped car following a halogen-lit motor coming towards me, kind of "peeped-out" from behind, and I caught a momentary glimpse of orange, and thought he was about to overtake into my path!
I understood that headlights were, by law, supposed to emit a white light, not white-depending-on-which-way-you're-looking-at-it light....
List of Afflictions...
C3 1.4 HDi ,XPic 2.0 HDi,Peugeot 306 TD,Renault Megane 1.6,AX 1.5D,AX 1.4D,Xantia 1.9TD ,XPic 2.0HDi
Xantia 1.9TD ,BX TZD ,BX TZD ,XM 2.1SD
BX GTi 8v,BX GTi 16v S1,BX 16TRS
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1379
Don't BMWs go to the scrapyard with their original indicator bulbs totally unused?Old-Guy wrote:Can beat that:- when the Xantia's (Jan 96 reg) N/S/R indicator light went in 2007, I discovered it was the original bulb.
- Donor 2023
- My Cars: '00 Xantia 110 bhp Hdi SX Estate 65K "W"
'99 Xantia 110 bhp Hdi SX Estate 310K SORN "V"
'98 Xantia 1.9TD SX Estate 150K Sold "T" - x 47
I tried to replace my sidelight bulbs with these
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
They were bright enough but the pcbs of the leds don't fit through the hole in the headlight reflector on the Xantia ....pretty disapointed!!
Previously I'd tried these
http://cgi.ebay.co.uk/2x-Car-LED-501-T1 ... 19c3d7971c
But they just projected light forward and because of the design of the headlight reflector in the Xantia, which seems to rely more on the light emitted from the side of the bulb, they didn't give out a lot of light.
Any other success stories for 501 sidelight leds?
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
'94 Fiat TipoTd 40K
