Jim, can't undo these nuts!CitroJim wrote:
If you look at 'tother end of the cat you'll see it terminates in an oval flange with two bolts in the flange. The underside will have a spring, a cup and a nut. You need to undo the 10mm nut whilst counter-holding the 10mm bolt head. You need ideally an assistant to help with this.
Just to be clear, am I supposed to be undoing the nut closer to the cat whilst counter-holding the other nut more into the engine? Or is it the other way around?
I have been trying to undo the side more into the engine bay, whilst counter holding the nut more towards the cat.
