hi Grumpyme and welcome
have you checked your pollen filter is not blocked as i belive this can/will stop air flow through the heater/matrix,
as you say both your heater hoses are hot,
regards malcolm
Xantia series I Heater Problem
Thanks Malcolm
I took your advice, the pollen filter had been changed earlier this year but I took it out - not much change in the heater output, still just warm.
There is mention in the previous posts about heater control flaps, but my heater control is marked blue, 18, 22, 26 red which makes me think that there may be some form of thermostatic control somewhere.
The Haynes manual is vague about the heater
Does anyone have any ideas?
It should take longer to warm up but should still reach normal running temperature. Yours could be a stuck open thermostat, does the rad slowly get warm as the engine warms up?MJM wrote:I have noticed that the heater in mine hasn't been as good as usual. I have also noticed that the engine temperature has been lower. Traffic on my local roads has been moving slower as well. I have come to the conclusion that the heater matrix, and internal fan, in the prevalent low ambient (-5 this morning) and slow speed is more than capable of doing all the work of cooling the engine. I doubt if the thermostat is getting hot enough to open normally.
There may be a bit of unnecessary matrix panic setting in.
Previous 90H S1 XM 2.1td SD Manual
Current 97P S2 XM 2.1td VSX Manual
Does the Xantia have a cabin temperature monitor like the the XM? Mine sits in the front interior light fitting with a fan drawing the air through the sensor. This tells the heater system how much hot/cold air to maintain temperature set on heater controls.Grumpyme wrote:Thanks Malcolm
Hobblerian,
>>it should take longer to warm up but should still reach normal running temperature. Yours could be a stuck open thermostat, does the rad slowly get warm as the engine warms up<<
It warms up ok, the thermostat is working properly, I just get the impression that the heater is dispersing a lot of heat which would normally be shed by the radiator. I like being toasty warm in the car Warming the incoming air from -5 to MJM's idea of warm takes a lot of heat. A decent run down the motorway (the engine purrs at 4000rpm) sees the water and oil temperatures up to their usual level.
MJM
1999 Dante red Xantia Exclusive 2,0 petrol. No smelly diesel for me. Now re-homed
2007 Wicked Red C5 Exclusive. Now a smelly diesel automatic for me.
