What is the highest mileage Xantia on the forum I wonder ?
Re: What is the highest mileage Xantia on the forum I wonder
Just thought I would add my Xantia to this list before I send it to the scrappy. Its a P reg 1.9 TD estate and just passing 330,000. It only had 74,000 on when I purchased it in 2002. On the whole its been the most reliable car I have owned, only failures being two clutch clips and 1 clutch cable. Still on its original injectors, turbo, Lucas injection pump, coolant pump drive shafts, turbo and CLUTCH!! Will still pass the speed limit and returns 43 - 45 mpg. But alas the front suspension is shot from to many pot holes and the cooling fans have both given up the ghost so guess its time to scrap it Its a real shame as the engine still sounds the same as when I got it, running till the MOT expires at the end of the month so time to get another 1000 or so on the clock!
Mike
Mike
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
For the sake of a pair of cooling fans!!! That's a waste.. can't be that hard to find any..
spheres? Or all the ball joint on the front too?
Seems small things for the need to give up after such sterling service!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Yes I know its a shame but reckon it needs ball joints and at least one lower arm, also front tyres are borderline and rad leaks! Been going to let it go for the past 4 years! The biggest problem is that the MOT is end of February, the least nicest month to be working on a car outside.
Shame. I got probably everything here too...
i have quite a large xantia stock i want to reduce..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Surely there cant be many Lucas TD Xantia's around either, most are Bosche IIRC and only the NA engine got the lucas...
Re:
To update this, the HDi is now on 241k and still drives like new and sounds perfect.Chris570 wrote:222k on the 2.1td.
but it'll never do another mile. engine was pulling like a train though.
my HDi is on 172k and still drives like new and sounds perfect
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2006 C3 1.6 HDi SX,
1971 D Special
2006 C3 1.6 HDi SX,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
- x 54
My Xantia just turned over 109,000 miles! Think it might be time to scrap it soon
Kev
'19 C4 Cactus 130 Flair
- Xaccers
- x 184
Re: Re:
So you've fixed it then? It was making a horrible noise last time I heard itChris570 wrote:To update this, the HDi is now on 241k and still drives like new and sounds perfect.Chris570 wrote:222k on the 2.1td.
DIY sphere tool
DIY sphere tool
It does indeed. Even I would give it a w*sh though. .Chris570 wrote: To update this, the HDi is now on 241k and still drives like new and sounds perfect.
Mines on 270k, still sounds WELL, still has the "Automatic cut out when driven like an arse" mode on it, but I can cope with that for now...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
That's a feature.citroenxm wrote:Mines on 270k, still sounds WELL, still has the "Automatic cut out when driven like an arse" mode on it, but I can cope with that for now...
2006 C5 HDi 170
1971 D Special
2006 C3 1.6 HDi SX,
1971 D Special
2006 C3 1.6 HDi SX,
Its a PITA to be honest, you NEVER know when the bloody thing is gonna happen, which is NOT fun AT ALL...Chris570 wrote:That's a feature.citroenxm wrote:Mines on 270k, still sounds WELL, still has the "Automatic cut out when driven like an arse" mode on it, but I can cope with that for now...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- New User
- x 39
My HDi is on 197k now. Doesn't use a drop of oil, which is changed every six months, and is as reliable as a daily driver has to be. She did 100k as a reps car in the first four years, then a bloke bought her and took her up to 146k before driving her into a scrappies as he had got a Mobility car. I bought her unseen for £250, replaced the windscreen and the sump, which the numpties in the scrap yard had used to jack her up, and seven years later wouldn't swap her.
She's had her fair share of work done, but nothing out of the ordinary - all six spheres, pads and disks, cat, rear height corrector and the dreaded heater matrix, but in 2012 I made the decision to spend money on her and keep her for good. Brand new LuK clutch, ball joints, track rod ends and bottom pulley should see another ten years out of her. Last year all I did was have the air con flushed and re-gassed.
Re:
Bloody right he wont!!!Eddie Nuff wrote: and seven years later wouldn't swap her.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Paul you fancying that XM 2.5 up north still??
