The second pipe runs right next to the one from the air filter down to the turbo. The engine changed around 2000 to have more anti-pollution gubbins - there is some sort of water / air heat exchanger down the back of the engine on the later cars, and this makes the cambelt a bit more difficult as the already difficult bolt in the top cover is obscured by the water pipe to (or is it from?) the heat exchanger. Some (maybe all?) 406 HDi 110s used a Dual Mass Flywheel, but I don't know of an easy way to tell. If one has had a clutch change that would take some potential expense away!RichardW wrote:Note that many listed on autotrader are incorrectly tagged - the only sure way to tell is to look for the second air pipe over the engine (present on 110 only), or check the VIN - letters 6 to 8 or so give the engine code - RHZ is 110.
Check carefully the gear change - if reverse is difficult this may point to an impending problem with the gear change cables, and they are dear to replace!
