what battery should my xantia have ?
My Cars: Bluebell the AX, Polly the C3 Picasso, Pix the Nissan Pixo, Propel the duathlon bike, TCR Pro the road bike and Fuji the TT bike...
x 6204
Contact:
Post by CitroJim »
addo wrote:If the battery telltale is green, then the battery should be all good - my experience is the telltale expires to a dead blackness long before the battery is kaput.
Indeed that is my experience of these telltales :twisted:
They tell untrue tales :roll:
VertVega
My Cars:
x 13
Post by VertVega »
I think we are missing the main point that the topic's battery capacity and this vehicle specifications do not match.
Even if this battery is a brand new one, it is not specified for a powerful diesel engine car.
It might be good for, lets say a 1.4 petrol, without aircon and electric consuming gadgets.
The green indicator might be seen even for some lower Cold-Start current values.
It can still start a car with a small engine, on a cold day.
Here's the link from Exide: ---> Battery Solutions - Selection <---
(Similar pages and catalogues are availble from Bosch, Varta and etc.)
In above link,
Try (2) - E-Catalogue, to find the batteries specified your vehicle
or
Try (3) - Selector, to find battery for your driving needs where
selection is made according to Engine size, Equipment, Climate and Driving conditions.
HDI
My Cars:
x 7
Post by HDI »
Yes but it may not be the battery causing the problem. I had similar symptoms with my car, fitted with a correct spec battery, but it turned out to be a faulty starter motor.
Might be a good idea to measure the battery terminal volts when starting and also the volts at the starter terminal. Should be around 9-10.5 volts when starting, could be lower with an underrated battery. If that is the voltage on starting then it could be the starter or an earth.
I do agree though that the battery should be the correct rating.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars.
x 1207
Post by Peter.N. »
Diesels require a lot more starting current than petrols, regardless of how new or good the battery is, if it can't provide enough amps, it won't start, or at least not easily, with the result that the battery is much more discharged at every start than if it started easily, which in turn considerably shortens its life.
Put a proper diesel battery on it and hang on to the other one for emergencies, or give it to someone for their petrol motor.
THELABMAN
My Cars:
Post by THELABMAN »
The C5 HDI diesel takes an 096 72AH 640-680 CCA I'd imagine to be safe the Xantia would be the same, I know I fitted one in my last Xantia and it was only the 1.9TD
And yes Monday the 25th there 1st cold day of winter I'd nothing, the battery was dead and up to then had been running fine but it was an 075/6 not sure of the AH or CCA.. a new 096 72A 650 CCA was £50 from a local battery specialist, that's £5 cheaper than the one I put in the Xantia 2yrs ago
Try this link here:
http://www.advancedbatterysupplies.co.u ... ry096.html
Citroen C5 2.0 HDI SX Hatchback - 2002 (52)
Xantia Sensation 1.9TD (T) Mallard Green (Gone to the breakers)
imperial21
My Cars:
Post by imperial21 »
i bought a halfords calcium battery 540 amp battery of a friend of mine who scraps cars, starter whizzs over much better !!!!
old battery was only a year old but i am giving it to a friend at work.
but surprise surprise the battery clamp was missing :(
has anyone got a spare battery clamp and bolt please ????
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
x 6204
Contact:
Post by CitroJim »
As said in your wanted post...
MK1 clamps are the same.
What's happened to yours Imperial?
Often, if the clamp is missing you'll find it's bolt is either sheared off in the tray or the thread is stripped so you may need a new tray or a tray repair too. They're all the same.
Just be careful with the bolt length if you have an automatic. Use too-long a bolt and you can screw it right into the autobox ECU which lives under the battery tray...
imperial21
My Cars:
the old battery did nt have a clamp on it,the bolt hole looks good my cars previous owner did nt exactly look after the car i think !!!
VertVega
My Cars:
x 13
Post by VertVega »
imperial21 wrote:i bought a halfords calcium battery 540 amp battery of a friend of mine who scraps cars, starter whizzs over much better !!!!
Seems that it has capacity 60Ah which would be good for your car 8-)
(Currently I have a 71Ah 670A under the hood :wink: )
imperial21 wrote:... but surprise surprise the battery clamp was missing :(
You can try a scrap yard. They are usually left on the car, rusting in peace ... :)
Xsara battery clamps are same type, I'm not sure about Peugeots.
Good luck.
Post Reply
