Is the only way to get to the float is to remove the tank? i'm a noob sorryOld-Guy wrote:Over-optimistic fuel gauge - I'd check the easy and obvious first:
1. Are the connections at the sender unit clean and and firmly located?
2. Remove the tank unit (it will drip so have a fuel-proof container to put it in) and check that the float arm isn't bent downwards and there's nothing preventing full travel. While you're at it, clean the in-tank filter if there is one.
Jim's suggestion about coolant stains as a give-away for pin-holes - look at both faces of the radiator (and elsewhere); the front face of the radiator is more vulnerable to impact damage and corrosion.
Couple Questions about Xantia!
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4922
Lift the rear seat squab and there is an access panel under it.
Lay down some polythene sheeting covered by something absorbent - old towels or sheets, and have a clean bucket or similar to put the pump/sender into.
Remove the access panel, tie up the pipes and leads before disconnecting them to prevent losing them down the side of the tank.
Unclip them then remove the locking collar - which can be a challenge.
Carefully lift out the pump and sender for checking and cleaning.
Added to the to do list, many thanks!myglaren wrote:Lift the rear seat squab and there is an access panel under it.
i went to buy the arm bearing and the guy there gave me thisOld-Guy wrote: Whining wheel is wheel bearing. Leaning wheel could be just wheel bearing if worn to extreme, but more likely to be rear arm.
http://us.gsp.cn/main/proView.asp?id0=2&id1=2&id=12
and since they don't speak english here i feel it's not the right one, any ideas?
OK Changed the wheel bearing and resolved the coolant leak which was just the cap, now when i jacked the car it seems like there might be a leak from the gear box i couldn't see where it is coming from or is it a leak or not, has anyone ran through something like this? also is there a recommended transmission oil?
- CitroJim
- x 6204
- Contact:
A favourite place for the gearbox to leak is from the driveshaft seals. It's recommended they're replaced whenever the driveshafts are disturbed...
Another cause can be overfilling and oil blowing out of the breather on top.
Only thing to do is to give the gearbox a good cleanup to remove all the old oil and then watching carefully to see where fresh leaks first emerge.
I take it that it is a manual gearbox?
yes it is manual gearbox, it looks like it's coming from the housing as everything else is clean, could be a crack? guess the best answer is to take your advice and clean it!CitroJim wrote:A favourite place for the gearbox to leak is from the driveshaft seals. It's recommended they're replaced whenever the driveshafts are disturbed...
