xantia hdi clutch
If your old clutch friction plate was worn at its outer edges (top)? and you are now experiencing clutch judder, there is a chance that the centre bearing that supports the output shaft is worn or the shaft is bent. The centre bearing is housed in the centre of the flywheel. It is one of those components that gets overlooked in a clutch change.
If the flywheel surface has wear ridges or surface cracks, not unusual in high mileage cars, the new friction plate will need to wear itself in. It may not be getting full surface contact until these wear peaks have bedded in. How many miles have you done since the clutch was fitted?
The make of cluctch fitted, LUK, should be OK, so I am told, but I only ever fit Valeo, as these were OE supplied.
Take the car back to the firm that supplied and fitted it and ask them to put it right, it is their responsiblity to put it right, at no extra cost to you.
Under the terms of the Sale of Goods Act, the parts fitted should be of merchantable quality and do the job they were designed to do. If you still get no joy, get onto Trading Standards and the CAB for legal advice.
Handyman
Handyman
I will upload the pictures tommorrow and you can all see what you think, i cant really take it back to the person who did as it was a cash job on a saturday afternoon, i wonder if it was a bit hurried as he did quick i wish i had seen the clutch he had fitted to be 100% sure he fitted an LUK clutch as somene else who drove the car said he thought it was cheap clutch ! I thought the bloke was honest and has done other jobs for me well.
Another thing i have noticed is that when i am towing the clutch has a better clutch bite espially with heavy loads ? ( i hope its not my immagination ! ).
Will the clutch wear out much faster or could it ever bed in ok ?
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
Even though you paid cash for the job, there is no reason why you should accept shoddy workmanship or dodgy parts. If he did not give you a receipt for the work, it is still his responsibility to resolve the issues.
You can still complain to Trading Standards and if you want to be really mean, Inland Revenue and if he is VAT registered, Customs & Excise!
It is not you that has transgressed the law, so do not be afraid to confront him. Sometimes a gentle hint about Goverment agencies is enough to get the situation resolved.
H
H
- x 3
Since when does paying cash mean you get a crap job? Cash is the normal method of payment as far as I'm concerned, but you're still entitled to a proper job. This has all the hallmarks of a cheap clutch being fitted. Oil contamination is unlikely, that would normally get worse as it gets hot. Very few transverse gearbox layouts use a pilot bearing (spigot) in the flywheel centre (can't be 100% the xantia hasn't but I'm 99% sure) so you can discount that as well. LUK are also used as O.E on Citroens as well as Valeo so it should work properly.
On the plus side judder often wears of after a few thousand miles. The clutch pedal is normally higher than the brake. The reason for this is that xantia brake pedals are lower than many cars as it does'nt use a conventional brake master cylinder.
- x 5
Not trying to be funny but the chances of the center bearing causing clutch judder are virtually nil so I would rule that out.handyman wrote:If your old clutch friction plate was worn at its outer edges (top)? and you are now experiencing clutch judder, there is a chance that the centre bearing that supports the output shaft is worn or the shaft is bent.....Handyman
Bent shaft etc, you couldn't bend one of those if you tried,so rule that out.
If the last clutch was fine with no judder you either have a defective LUK clutch, (unlikely) or he has fitted a cheap re-con clutch. (likely)
I put my money on the latter.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
- CitroJim
- x 6202
- Contact:
I'm not so sure. There are grave warnings about having the (heavy) 'box well supported as you mate it back on the engine. The weight of the thing hanging off the input shaft might well do for it if they were careless.uncle buck wrote: Bent shaft etc, you couldn't bend one of those if you tried,so rule that out.
I must admit, I tend that way too...uncle buck wrote:I put my money on the latter.
You would more likely damage the input shaft bearings though than bend the shaft. would have a similar effect but you'd also see gearbox oil loss throught the fudged bearing.CitroJim wrote:I'm not so sure. There are grave warnings about having the (heavy) 'box well supported as you mate it back on the engine. The weight of the thing hanging off the input shaft might well do for it if they were careless.uncle buck wrote: Bent shaft etc, you couldn't bend one of those if you tried,so rule that out.
To me it sounds like a cheap clutch, although it can't be a transmech clutch as its lasted more than 3 minutes (nasty things)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2006 C3 1.6 HDi SX,
1971 D Special
2006 C3 1.6 HDi SX,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
- Xaccers
- x 184
We fitted a transmech clutch to Cassy over 2 years ago and had no problems. (approx 40,000K)
DIY sphere tool
DIY sphere tool
Had a quick look on the Citroen Service site and cannot see a pilot bearing listed for the input shaft.
As for bending or breaking parts, I have seen supposed bulletproof parts suffer at the hands of the wrong idiot, so it could be possible to bend or break shafts and bearings if the gearbox weight is hanging on the end of the shaft.
It may possibly be that the friction plate is off centre.
However, whatever all us "saw-doctors" say, the only way you will get the clutch problem resolved is to start checking the components fitted and how it was done.
What did William Morris say: 'He who buys cheap, buys twice.'
Handyman
Handyman
- x 3
I use Transmech on a regular basis but not for the bigger Citroens and peugeots, due to problems with judder. Of Course a clumsy fitter can damage parts but once an input shaft engages in the clutch spline it normally slides straight in. As previously said, dismantling is the only way to find out.Xac wrote:We fitted a transmech clutch to Cassy over 2 years ago and had no problems. (approx 40,000K)
- x 5
- x 3
- x 5
Exactly, that's what I didn't understand about the comment, I wondered if he meant something else.flying clutchman wrote:You're right it can't. The very first time the clutch is operated it will centre itself!
This will almost definitely be a warped or high spotted flywheel.
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped )
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Basicly thats what the guy who did my clutch says it is , high spots on the flywheel , i thought the clutch would bed in and the problem go away, i guss wishful thinking ! its a pity as it spoils the lovely drive of my car.
I am keeping an eye out for a spare flywheel anyone help ????
