Xantia Airbag Removal
Re: Xantia Airbag Removal
No, I don't think you should split it in the middle. If it's the same as on my 1995 1.9TD, then I think (memory's going nowadays ) that you slide a thinnish screwdriver or similar under the connector and gently lever it off. Suggest you do this gingerly in case I'm wrong.
No doubt someone will be along shortly to confirm one way or the other.
Martin
1995 Xantia TDLX (deceased )
- CitroJim
- x 6206
- Contact:
Nope. that's the right method... The airbag has a small socket on it's back face in the shape of a 'D' with two pins. The side face of the orange bit in the picture has the reverse. It'll clip out quite easily with the use of a small screwdriver as a lever.
Disconnect the battery and leave disconnected for at least 10 minutes before doing it though...
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4922
All these blasted clever connectors with each their own method of dismantling is nothing but a nightmare. So easy to break them if you don't know the trick of releasing the catch and it is always the most crucial ones that disintegrate when the incorrect technique is applied.
- CitroJim
- x 6206
- Contact:
That's so true Stevemyglaren wrote: So easy to break them if you don't know the trick of releasing the catch and it is always the most crucial ones that disintegrate when the incorrect technique is applied.
Cheers guys, I succeeded in removing the bugger, it was plugged into two pins on the back of the airbag plate. Next job is trying to source a replacement part, found an exact match here http://bartebben.com/parts/citroen/xant ... 30480.html weirdly couldn't find it on valeo's website.
None on ebay, so time to start calling round breakers, I hope a new one fixes my airbag light otherwise I think I'll be send my xantia to the scrap yard!
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
Check with citroenxm, as he is likely to have one. He also charges realistic prices.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Cheers Hell Razor, I'll drop him a PM
Steve; there is a freaky lil girl on your Avatar. I can feel my fillings getting sore with her treacly warblings
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
I wouldn't describe her as 'freaky'
More 'phenomenal'
Incidentally, RIP Lou Reed
More 'phenomenal'
They are all going Steve. Playing "Berlin" on the old Lenco tonight
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- falling-out-with-my-car
- My Cars: Citroen C5 Aircross 8 speed Automatic, Flair Model with far to many toys and nice comfy armchair like leather seats. ha ha Ive just had a conversation with the car. setting everything up verbally
- x 24
danny,
if you can't fix it check your messages,
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1300
- Contact:
Or you could put in a resistor until you find the correct part....it would save scrapping it. http://www.ebay.co.uk/bhp/airbag-resistordanny13 wrote: None on ebay, so time to start calling round breakers, I hope a new one fixes my airbag light otherwise I think I'll be send my xantia to the scrap yard!
Activa, the Moose Rider
3x C5x7 Steering racks and counting
Some great advice, thanks gents. Fitted the new switch, but in the process bust one of the damn plugs that connects to the rear of the airbag, The plug was connected onto the pins shown in the arrow:
This is how it was before, assume these are required to have a working airbag circuit?
