Eolys Rip Off
cachaciero
My Cars:
x 9
Post by cachaciero »
Just done a bit of Patent research interestingly Rohdia have a patent on the whole exhaust FAP system applied for in 1999.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX
x 4922
Post by myglaren »
If you just add diesel to the Eolys tank without removing the FAP filter then the filter will clog up fairly quickly as it needs the Cerium to reduce the combustion temperature of the carbon particles to be burned off in the filter.
JohnD
(Donor 2022)
My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1
x 72
Contact:
Post by JohnD »
Clogzz wrote:Think to have read on a French site to put diesel in the Eolys tank.
You're right - I've seen that - but it's b*******. What would be the point in having the ecu inject 30mls of diesel into a just-filled diesel tank - and the FAP system work as it should?
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Kowalski
My Cars: Ex 05 C5 2.0 HDI Exclusive 145k
Ex 97 Xantia 1.9TD SX 144k
Ex 94 Xantia Dimension 1.9TD 199k
Post by Kowalski »
If you remove the FAP, the system doesn't need any Eolys.
Homer
My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Xantia 2.0 Exclusive CT turbo Break,
Peugeot 807 2.0 HDi 110,
Renault Grand Scenic, 2.0 diesel (150bhp)
C5 X7 2.0 HDi 160 which put me off French cars possibly forever
x 16
Post by Homer »
But then you would still need to tell the system that there was no FAP, in which case it won't try injecting Eolys, in which case you don't need anything in it's tank.......
......I think.
Clogzz
My Cars:
x 36
Contact:
Post by Clogzz »
I’ll try digging up the story to find out what exactly they did.
The purpose was to fool the system into believing that it was functioning normally.
There was no preoccupation with emissions.
2002 C5 2.0i AL4 230,000 km 76372389
JohnD
(Donor 2022)
2018 Citroen C4-B7
2011 Citroen C1
x 72
Contact:
Post by JohnD »
Rooting around in the garage this morning I've come across a few 1oz canisters of Cerium oxide. Anybody fancy concocting some home brew Eolys? :P
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
cachaciero
My Cars:
x 9
JohnD wrote:Rooting around in the garage this morning I've come across a few 1oz canisters of Cerium oxide. Anybody fancy concocting some home brew Eolys? :P
Ah! well al we need now is some iron oxide and paraffin and we are away.... lets see yes I have a few bits and pieces which need the rust grinding off I think maybe together we could have the ingredients for DIY EOLYS, however..........
In my case the low level thermistor looks like it's shot in which case the car is going to get de-fapped so there won't be a need.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
JohnD
(Donor 2022)
2018 Citroen C4-B7
2011 Citroen C1
x 72
Contact:
Post by JohnD »
cachaciero wrote: al we need now is some iron oxide and paraffin
Surely diesel could act as the 'vehicle'.
But why is this: I used Cerium oxide as a polishing compound on stone; therefore it must be abrasive. In fact Cerium and T-cut are both the same colour, so cerium might be the active ingredient in T-cut. Wouldn't that be damaging to the fuel pump?
I see the Eolys on ebay went for 29quid per litre. But I wonder where it came from? Maybe the same country as many of our Lexias.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
MikeT
My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon
x 231
Post by MikeT »
Forgive me if I'm misunderstanding but isn't it possible to fool the ECU using resistors in place of the pressure sensors, allowing removal of said FAP without flagging a fault or causing limp home mode? I think fuel is expensive enough without having the need to add, what must be some of the most expensive liquid known to man?
kenhall1202
My Cars: '05 C4 2.0HDI Exclusive
'07 Lexus RX400h
Past:
'73 GS 1220 Club Estate (a good intro to hydraulics and rust)
'74 DS D Super 5 (Superb comfort and even more rust)
'?? Dyane (fun + rust)
'?? CX 2400 GTI (served me well)
'89 CX Safari 2.5 DTR turbo (aka "the hearse" an excellent family load lugger)
'97 XM 2.1TD (Reliable and economical)
Post by kenhall1202 »
This Romanian site http://www.phones-direct.ro/public/fapsensor/index.html has some interesting projects re DPF monitoring and DPF system removal. I contacted him (he's already an FCF member I think) last year with a view to buying a DPF monitor for my C4 (~£30) but for whatever reason he couldn't supply to the UK at the time. I'm asking him again just now -awaiting a reply.
Ken Hall
cachaciero
My Cars:
x 9
Indeed one of the uses for cerium oxide is as an optical polish. Damaging to the fuel pump well I am not a chemist but I suspect that would depend on particle size and how it was bound to the carrier liquid, this may all be down at nano sizes.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
cachaciero
My Cars:
x 9
MikeT wrote:Forgive me if I'm misunderstanding but isn't it possible to fool the ECU using resistors in place of the pressure sensors, allowing removal of said FAP without flagging a fault or causing limp home mode? I think fuel is expensive enough without having the need to add, what must be some of the most expensive liquid known to man?
In a word yes and in another recent thead on FAP removal I have said that it just requires that the FAP dif sensor be replaced with a suitable network of resistors fitted in place of the diff pressure sensor to simulate the pressure drop of a "clean" FAP.
This should work fine unless the software in the ECU is clever enough to work out that a constant diff pressure for all rev ranges is an error, I would work on the basis that it isn't :-)
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
cachaciero
My Cars:
x 9
Just an oddball thought, assuming that a 50mm dia exhaust pipe is adequate a completely choked FAP would need 25 10mm dia holes drilled in it to equal the cross sectional area of a 50mm dia pipe but as the walls of these holes would be rough the conductance would be lower than an equivalent pipe so the pressure drop may be enough to fool the sensor into believing it has a good FAP of course a completely blocked FAP is unlikely so maybe 24 holes would be enough.....??
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
woodywoodpecker
My Cars:
Post by woodywoodpecker »
cachaciero wrote:
Paul-R wrote: You might be the first one to take the plunge though.
No I won't be the first I have read in other fori of others that have done it. There are "several "system Approaches" to removing it but the one thing I would like to be able to do if possible is to remove the ceramic element complete because as I said I do think that the use of a FAP is an environmentally friendly thing to do and if in the future it should be that the required bits from a broken 2004 on car became available I might want to re-instate it.
cachaciero
I have removed my fap and cat on 2.2 c5 hdi 2004, and all i can say is you will not re-instate it after you have drove your car without it. i have a lexia but this is not used to remove it from the ecu you need a galletto cable to read your ecu file to laptop, Then run your file through software that removes all reffrences to the dpf and Eolys from the ecu. Once the modded ecu file is done simply write it back the ecu then take the dpf and cat off exhaust and smash the guts out of both and refit to car. I have done 3000miles now and my car pulls like a train no black smoke 4-5mpg better fuel and flew through mot. total cost for me was £25 for cable and 3hours of my time to remove and refit exhaust. This also dissables the Eolys additive from working so no more dpf or Eolys to worry about again. Did a mates peugeot 406 2.2 hdi yesterday he can't believe the difference in performance. Any more info or help just mail me.
Post Reply
