Can you please clarify, did it fix both lighter and light?Penguin wrote:Thanks for your help on this one, it was indeed the fuse (in the position stated by Paul NOT the one stated by BOL). Simple fix once I had the correct fuse identified.
Cigarette Lighter not working
Actually haven't checked the light, but the socket is working which is what I was really worried about. I'll check the light later and let you know.MikeT wrote:Can you please clarify, did it fix both lighter and light?Penguin wrote:Thanks for your help on this one, it was indeed the fuse (in the position stated by Paul NOT the one stated by BOL). Simple fix once I had the correct fuse identified.
95 Xantia 1.9td SX
- Old-Guy
- My Cars: 2011 Grand C4 Picasso VTR+ 1.6HDi in Kyanos Blue
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - now owned by XanTom
1998 Xantia 2.1 VXD Estate in Mauritius Blue - R.I.P. (terminal tin-worm) - x 17
You will know how to fix it next time then! I find that for some reason, this fuse has blown several times. I only use the socket for the power adaptors for my TomTom and my mobile phone (the latter has been dead for months). I too wonder if constantly pulling the tray in and out (to remove the ashtray to plug-in the TomTom) has caused a problem.
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - after 11 years now owned by XanTom
- Xaccers
- x 184
Once useful way to remove the need to keep pullin the tray in and out is to fit one of those 4 way sockets to the side of the passenger footwell, about where a 12v socket is on S2 cars.Old-Guy wrote:You will know how to fix it next time then! I find that for some reason, this fuse has blown several times. I only use the socket for the power adaptors for my TomTom and my mobile phone (the latter has been dead for months). I too wonder if constantly pulling the tray in and out (to remove the ashtray to plug-in the TomTom) has caused a problem.
I've got that in Cassy and it's great. The one in Jenny also has LEDs indicating car battery charge too.
DIY sphere tool
DIY sphere tool
Sorry to drag up an old thread, but this one has changed its characteristics somewhat. Fuse had blown again so I replaced it. Wife connected up the satnav and the fuse had blown again. As I was driving I didn't do anything straight away but when I got stuck in traffic I opened the box and pulled out the blown fuse and went to replace it with a new one by sense of touch. Put in the new fuse but as I did so there was a big flash from the fuse area and the fuse blew immediately. Decided to wait until properly parked up to try that again! When we arrived at journey's end I tried again, nothing plugged in to the socket, and attempted to fit a new fuse, same thing - flash! and blown fuse. Just as a sanity check, the fuse goes across the 2 connections in direct line with the column of fuses above it and not across the other 2 connections? If I have that correct then how on earth do I remove the ash tray to get at the rear of the socket?
Ta chaps.
Ta chaps.
95 Xantia 1.9td SX
