I Need Help Please Citroen Xantia 97, 1.9td
- Xaccers
- x 184
Ok to recap, please correct anything I've got wrong:
You've run the car with just the needle lift sensor and the rev counter works.
You've run the car with just the crank sensor and the rev counter works.
Fuel filter and housing have been replaced with new filter and unbroken housing and now there is at most only tiny bubbles of air getting in.
You've got lack of power and black smoke.
Have you?
Lifted up the back seat behind the driver's and removed the fuel sender (put cable ties on the fuel lines so they don't fall down the side of the tank, and have new jubilee clips ready to refit them, be careful removing the ring that holds it all in) then checked the mesh filter on it's base as this gets clogged up over the years with dirt etc, and would explain the gunk in the heat exchanger under the fuel filter housing.
Unplugged the small rubber hose that goes from the left electrovavle at the back of the engine bay between the engine and the LHM resevoir. This goes to your egr so best to disable it.
Looked in the stickies section for a lexia near you?
The K light comes on when the ECU can't adjust the timing of the pump, normally because of a problem with the TDC/NL sensors, but can also be due to fuel starvation.
Lexias can check the status of the ECU and pump.
Have you?
DIY sphere tool
DIY sphere tool
Hey thanks for the tip i think the EGR is already disconnected as there is a loose vacuum hose near the square LHM tank i couldnt see where it went and the other one goes to the cold start cable.
i will have a look the tank thing check it out tonight if there is enough light.
i live in ross on wye (HR9 5PD) and the nearest lexia is bath looking at the map, thats a long long way to go.
right have just checked the sender unit was a little bit of gunk now removed.
air lines are all fine seal around the new filter is good and the air flow is great.
boost is now better but still on the low side the balck smoke starts at the turbo's earl end spooling. at hte higher rev it is a more grey- white in colour and no there is no water in oil or oil in water, and no oil in deisel either lol
the k light is still on it still feels like the turbo is kicking in too late
the injector 3 sensor is fine and the TDC sensor is fine and i am pretty sure the EGR is not connected to the vacuum hose,
- Xaccers
- x 184
We're getting closer to having to head for a lexia to see what's going on inside the pump.
What's the boost like with the pipe disconnected between the flying saucer on the pump and the air trunking?
On the top of the flying saucer, is there a metal cap, which hides the fun/smoke screw, or can you see the 13mm lock nut and 27 torx screw? If you can, is the yellow paint still in tact or does it look like someone's been turning the screw? How deep from the top if the pit it's in is the screw?
How flexible/new are your leakoff pipes between the injectors? If they're stiff at all, replace them. Probably not related to your issues but worth checking anyway.
Can you blow down the fuel return pipe? If not get an air line on it to blow any gunk back to the fuel tank.
Are you free the weekend after next to come to Little Horwood (it's only a 4.5hr round trip) as I'm sure someone at the rally will have a lexia.
DIY sphere tool
DIY sphere tool
- Old-Guy
- My Cars: 2011 Grand C4 Picasso VTR+ 1.6HDi in Kyanos Blue
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - now owned by XanTom
1998 Xantia 2.1 VXD Estate in Mauritius Blue - R.I.P. (terminal tin-worm) - x 17
As a possible temporary solution to the fuel consumption problem, does it smoke all the time or only when you put your foot to the floor? If the latter, try to be gentle with the throttle.
Your basic problem is either 'overfuelling' - too much fuel for the amount of air, or retarded injection (too late for all the fuel to burn).
I think you need to back track to the couple of days when everything was fine (wasn't it?) to work out what's gone wrong again.
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - after 11 years now owned by XanTom
