C15 noisy gearbox
Dave.P
C15 noisy gearbox
Unread post by Dave.P »
Hi, new member here. I have a C15 van with only 28,000 miles on the clock, problem is the gearbox is very noisy, in neutral with clutch out and engine idling its fine, its only when the vehicle is moving that the noise starts, does it in all gears but when pressing the clutch in to change gear the noise stops until you let the clutch out again, gets slightly louder when revs are higher. Even if i drive at idling speed in first gear the this strange noise is noticable, hard to describe what it sounds like but I know its not normal, anyone know what it could be please?
Citroenmad
x 110
Unread post by Citroenmad »
Have you checked the gearbox oil level?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 8391
Citroenmad wrote:Have you checked the gearbox oil level?
I'd be inclined to change it. It's not unknown for garages, through ignorance, to put the wrong stuff in. I've even seen one (my daughter's 206) filled with ATF!
The ONLY oil to use is 75W/80 and the best is Total BV75W/80. Failing that, Comma make a good 75W/80.
The use of any other grade can cause all sorts of problems...
Hopefully then the noise will cease. If not, there is an internal problem, most likely a bearing.
When you drain, critically inspect the old oil for bits of metal and other debris and if the drain plug has a magnet on it, see what's on that.
I once knew a 205 owner who drained a couple of ball bearings out of his gearbox....
x 94
Unread post by citronut »
hi and welcome Dave
are you certain its the box and not the clutch thrust bearing, maybe a wheel bearing or even brakes,
so you say its only whilst you are moveing along,
were abouts are you
regards malcolm
Dave.P
thanks for the replies everyone, I am wondering if it is the oil, the next problem is how do I check the gearbox oil, I'm assuming theres a filler plug somewhere, I know only too well what happens when you undo the wrong one. Hi Malcolm, its definately transmission related and only happens when the gearbox is under load. I'm near Dumfries in Scotland.
Dave.P
Gearbox oil changed, here's the old stuff, surely it shouldn't be as dark as this (a browny green colour) :?
x 8391
Looks 'orrible..
And I'm worried about the pile of screws too :lol: :lol:
Thing is, has it helped the noise?
Dave.P
:D thankfully the screws didnt come from the gearbox lol. Unfortunately it hasnt cured the noise, surely the gearbox shouldn't be worn at 28,000 miles, any I'll just keep driving it the way it is and put another gearbox in if/when this one packs up.
x 8391
Thing is Dave, there's noises and noises. Some are good (in that the 'box will soldier on for ever) and some are real harbingers of doom.
Generally if the noise sounds smooth, almost musical and is not jarring then it's of the former sort. One that makes you grit your teeth, jars through your head and is like fingers down a blackboard then it is invariably of the latter sort..
flying clutchman
x 3
Unread post by flying clutchman »
gearboxes are easy to chame on c15 diesels and not too hard to come by, so I'd stick another one in.
Dave.P
I think thats what I,ll end up doing, should be some C15 gearboxs at the local salvage. Thanks for the help everyone.
Kowalski
Unread post by Kowalski »
CitroJim wrote:I once knew a 205 owner who drained a couple of ball bearings out of his gearbox....
Is there a special refill hole for putting the new ball bearings in? ;)
uhn113x
x 3
Unread post by uhn113x »
It's where the sawdust goes!
Mike in West Yorks
1982 GSA Pallas
1982 Dyane
1997 ZX Dimension
