Oh well.
I just got back from the local auto store with a set of 4 NGK glowplugs for £27.96.
I asked him for the best quality ones, and those are the ones he gave me. Presumably, he didn't have beru plugs in stock.
But how do I replace them? I have never changed anything on the diesel engine before. I have replaced the spark plugs on a 205 petrol engine many many years ago. I presume it is similar.
But can anyone give me a link to a page with a diagram of a 406 1.9 td lx engine with the glowplugs located on them?
And also, with regards to the process of replacing them in a xantia, is it the exact same engine as in a 406? And how do I know it's a lucas pump? Is this the same as the primer pump/bulb, or something else?
Many thanks.
406 'Rocking'
- spider
- My Cars: Soon, I hope...
- x 77
- Contact:
It will be 99% certainly a Bosch pump, never seen a Lucas pump on a 406. If its got a Lucas pump someone has changed it.
Basically you disconnect the wiring between them and then unscrew them, and replace them and then re-fit the wiring.
Sounds easy, it is mostly, but access is a bit tricky, especially the one behind the pump. Last time I did one I used a telescopic magnet to help.
Andy.
